Rare parts for sale
Date: 09/10/2018 08:38 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
New cam
Date: 01/23/2017 05:11 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 12/31/2017 09:03 pm
Date: 02/28/2018 09:37 am
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
  • Online today: 394
  • Guests: 269
  • Total: 269
what is stock 2.0L redline?
Started by americanpintobean, March 21, 2012, 11:49:36 AM
mines a 2.3 but the sound of it at 7200 through a 3" exhaust with a bullit muffler is awesome.......
540Hotrod
7000+ is not a problem at all strength wise. Mine had a cam/header and milled head...did fine up there.
JIM
Quote from: fast64ranchero on March 23, 2012, 11:17:46 AM
A stock 2.0L will turn 6,000rpm's all day long, the bore/Stroke and rod ratio make it a very forgiving little engine, the power cure will be below that point, the stock 2.0 cam is pretty aggressive for a stock engine.
My Stock 2.0 was just a wailing engine with little power past 5 grand, I had header too. Then I  put on a modded stock intake man with Weber 38 DGAS and whoa! This thing needs fuel! and then it decided to blow a head gasket..  Hmm !
Went to race motor then..
fast64ranchero
72 old V-8 parts Pinto
73 pinto, the nice one...
Quote from: 71pintoracer on March 22, 2012, 06:57:03 PM
Let us know what the rules are. Back in the late -'70's when I started dirt track racing the engines had to be stock. But that didn't mean you couldn't tune for maximum performance. Open air cleaner, no choke plate, some carb work, drill the jets, cut the head .060", made shims for the stock cam pulley to get the cam timing right, (CRITICAL STEP) good valve springs, turned it 7000 RPM. Had to have a muffler so I took the guts out of a glass pack and used the shell (lol) with 21/4" pipe, thing sounded like a pissed-off bumble bee!
AmericanBean, and all..
Let us suppose that there is a peak power and torque curve for a "stock " engine. The Redline term is a nebulous one. Does it occur after the power peak? Does it occur before valve float? Do the rod bolts breaking from harmonic stress indicate a Redline #.  The point is Unmodified ( even Bluprinted ) stock motors don't have a specific Redline. It's a defensive data point to defer destruction .. It's not a set  RPM. Engine builders look for this all the time in their quest for power, And reliability.
My 2 cents..
americanpintobean
pintosopher;  I needed to know for hornet racing.  5500 might be the end of power, but what is the redline?  the point at which the motor goes out of time on the high revs.  obviously before you float the valves.
Sounds about right. I know brownie can rev pretty darn high. I have never had it up to 5500 (by ear), but it has never lost power! :D
Thinking about it, Brownie has a 2.0L and a speedo that goes up to 110mph, while my 78 has a a 2.3l and a speedo that goes up to 85mph, naturally I would suspect it can rev higher. Both motors are stock, aside from the 2.3 being bored out to .030 over and a roller cam, but I leave the red line on the tach at 4k RPM, as it's just SCREAMING at 3500.
racer99
I believe 5500 is being optimistic at that.
Not to be sarcastic but why do you need to know? The stock US spec 2.0L make no power past 5500rpm. :P
americanpintobean
