cam pulley
Date: 05/30/2018 04:56 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Hatch needed
Date: 09/10/2017 09:16 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
80 pinto original
Date: 08/04/2019 10:45 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 02/10/2017 09:30 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
  • Online today: 600
  • Guests: 283
  • Total: 283
All lights go out on 77 Bobcat.
Started by meandmymercs, March 13, 2012, 07:56:06 PM
meandmymercs
Found the problem with the short in the Bobcat today.... I ran a ground wire from the negative battery terminal to the  chassie and have another one the battery to the motor block.. Cool we be drivning at nite now.. Thanks Guys...
77 merc bobcat
70 merc cyclone gt
61 merc meteor 800
64 merc comet caliente
In addition to the above, suggest checking under the dash to see if clutch pedal lever and/or cable is rubbing the wiring harness or a connector.  Those intermittent problems are hard to find.
mrskydog
It sounds like a Ground issue ,check and clean all the Firewall grounds. The only thing I can think is by depressing the clutch you always get a slight firewall flexing. Other than that my first thought with the Headlights flashing on and off would of been the in dash Headlamp Switch......relay built in switch tripping-on and off........Kirk
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
meandmymercs
Weird thing today the wife drove the Bobcat to work in the AM. She had the headlights on about a block from home they started to flicker. (Actually all the lights went out dash and all.)   While driving she slightly touched the clutch pedal with her foot not engaging it. Then the lights  stayed on all of them.. Not sure if this is a grounding issue or something to do with a starter i changed on it last week.. I to drove the car around the block this evening and i had the same issue with all the lights flickering on/off. When i gently touched the clutch pedal they came on strong.. ???? Also the blower motor was affected to  when driving it, it stopped too when running, then touched pedal and WAA LA they came on....  Any help would be appreciated..
Thanks David
77 merc bobcat
70 merc cyclone gt
61 merc meteor 800
