  • Online today: 309
  • Guests: 370
  • Total: 370
How do you store engines to save space??
Started by johnbigman2011, February 27, 2012, 01:21:58 AM
johnbigman2011
The wife has picked me up six of the dollys from Harbor Freight. I'm going to mount the 2x12 idea on them and see how that works.
racer99
Those freight dollies are on sale for 7.99 here in S.A.
1000 lb capacity.
johnbigman2011
Good ole Texas ingunuity for sure. I think I'll go that route. Thanks for all of the help.
SeanP
I once made a stand for a MGB motor by making a box exactly the size of the oil pan flange.  All you need is 1 each 2" X 12" board, some appropriately sized screws, a saw, and screwdriver or even better, a drill.  Measure the outside circumference of the oil pan and build a box.  The footprint of the stand will be whatever the size of the oil pan is.   Before you say it sounds tipsy, it was actually pretty sturdy.  You could also make the front and back sides slightly longer for stability if you're worried about it.
Biloxi, MS
1978 brown Pinto Pony trunk
facebook.com/thatbrownpinto
Quote from: johnbigman2011 on February 27, 2012, 01:21:58 AM
I did notice one time while looking through eBay across the big water that they had a floor base one. Just the picture wasn't clear enough for me to kick into fab mode.
since you mentiond "fab mode" I saw something similar to this
http://www.ebay.com/itm/MOTOFEET-ENGINE-CRADLE-STAND-FORD-289-302-351-MOTO-FEET-/250990884733?pt=Motors_Automotive_Tools&vxp=mtr&hash=item3a7038f77d
couple years back for the 2.3L with wheels on the bottom feet to move. Bolted to the standard mount holes on the engine. Use your imagination and something could be fabbed up. I wish I would have bought a couple myself
289Wagon
 I use the small movers dolly from Harbor Freight  # 93888. There is a complete 289 on one and a short block on another. They have some bad reviews, but they seem to be from people trying to use them on a rough or cracked surface. There are other reviews from people using them for eng. or trans. Stores eng. right against wall + it's great for moving an eng. under a stationary hoist to put it on an eng. stand. Beats putting the hyd. hoist together just to do that. They are SALE now for $11.99.
I personally would only trust it on a small stand, however I have seen people use a thick sidewall tire, with the pan sitting in the middle. If I were forced to go that route I would put a thick foam under it, just to give the pan something to sit on.
johnbigman2011
OK, here is the question..... My two car garage is shrinking more and more here lately with a t-bucket and a 72 pinto in it. While acquiring the two, I have come up with multiple engines and trans and I need to know how to store them and save space. Harbor freight engine stands are cheap enough but they still take up space. I would just like to line them up against the wall.
