Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 06/05/2018 09:13 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 08/26/2018 06:23 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 12/24/2016 04:13 pm
  • Online today: 394
  • Guests: 297
  • Total: 297
weather seals
Started by thecustommuffler, February 16, 2012, 01:06:54 PM
71hotrodpinto
So far from what i can see, Steele Products is a great start
Ebay Is also a great start and Steele has many of thier Pinto stuff there. I think that the only thing thats not carried by them is the window channel felt and the hatchback seals. Also i hope you dont have a factory sunroof. (did the Pinto ever have one???? hmmm..)
Heres an ebay link to get you started.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=pinto+weather+strip&_sacat=See-All-Categories
This should get you started!
Good luck!
Vulcanized Back Window Channel
[/size][size=-1][Model & Style Charts][/size]
Look good coming AND going.
Are you going to leave what is frequently the largest exposed piece of rubber on your car to just anybody? If you want top notch fit and performance along with blue ribbon looks, look no further. Put the tight, reliable seal and lasting good looks of one of these gaskets in your car.
For your convenience, materials required for proper installation can be found byclicking here for Glazing Compound.
[/font]
Model
Note
Part #
Price
Pinto & Bobcat with trunk 70-3287-81[/size]
[/t]
[/t][/t]$94.60/ea.
Fixed Quarter Window Weatherstrip
[size=-1][Model & Style Charts][/size]Seal, rear stationary quarter. Replaces factory #D2FZ-6229732 & #D2FZ-6229733-A.
    • May 1972-1974: Ford Pinto
      1975-80: Ford Pinto & Mercury Bobcat
    • 70-3288-77.....$ 296.40/pr.
      Door Weatherstrip Kits
      Steele is better. It's an open and shut case.
      No other piece of weatherstrip on your car is asked to do more, or take a greater beating than the door weatherstrip. These strips need to be correct and durable. If you want doors to open easily, close tightly, and seal firmly for years to come, look no further.
      See the next section for auxilliary weatherstrips if they are required.
      For your convenience, materials required for proper installation can be found byclicking here for Adhesives & Cleaners.
      Pinto & Bobcat70-3121-72[/size]
      [/t]
      [/l][/l][/t][/t]$103.30/pr.n/a-
      Decklid Weatherstrip Kits
      This section contains ready-to-install trunk weatherstrip kits. These kits contain sufficient materials for the decklid and/or the gutter in the body.
      For your convenience, materials required for proper installation can be found by clicking here for Adhesives & Cleaners.
      Weatherstrip, trunk. Replaces #D5D2-6643720-A.
      • 1972-80: Ford Pinto with trunk back
        1975-80: Mercury Bobcat with trunk back
      • 70-3347-84.....$ 40.70/ea.
        Pre Assembled Beltline Weatherstrip
        These side window horizontal seals typically come ready to install with finished ends and body curvature bends for a factory like appearance. They may be available in your vehicle in two quality levels, Standard and Original. Standard Windowfelt Kits are made from standard aftermaket material. The Original Windowfelt is constructed from limited production material which may be a closer match to the vehicle's original appearance. These sets include the inner and outer seals for all side windows unless noted. Two (2) or four (4) piece sets without inner or outer indication are always outer seals only.
        Ford Pinto & Mercury Bobcat. Original material. 80-0669-57[/size]
        [/t]
        [/l][/t][/t]$106.80/set
        Vulcanized Windshield Channel
        Ready To Install. Great Fit.
        Authentic look
        Few things are more essential to a weatherproof car than a quality windshield gasket. With authentic look and fit, our gaskets perform as well on the Concours as well they do on daily drivers.
        When only the best will do, go with Steele Rubber Products.
        Any notation regarding reveal molding implies vehicles that had a chrome trim around the windshield gasket. For your convenience, materials required for proper installation can be found by clicking here for Glazing Compound.
        Model
        Note
        Part #
        Price
        Ford Pinto & Mercury Bobcat 70-3171-50[/size]
        [/t]
        [/t][/t]$95.40/ea.
    [/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table][/td][/tr][/table]
    B303,1.7 Rockers,beehives
    '68 port/polish heads
    Coated Must II headers
    Edelbrock Airgap
    Holley570,Msd dist,CraneHI6
    Mil
    Quote from: thecustommuffler on February 16, 2012, 07:41:22 PM
    If there is a complete package then, all.
    no.. sold seperatly from different sources
    thecustommuffler
    which ones you looking for... windshield, doors, hatch, etc... there are options for all but need to know which you are looking for.
    thecustommuffler
    I did a search and came up empty. Is there anyone making weather seal kits for a `78?
