Date: 10/14/2019 08:24 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 10/05/2017 02:26 pm
Date: 11/04/2018 02:34 am
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
1979 pinto
Date: 04/19/2018 02:02 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 06/22/2017 07:19 am
  • Online today: 587
  • Guests: 239
  • Total: 239
Adding Gear Oil to Rear Differential
Started by John Turner, February 15, 2012, 03:03:48 PM
John Turner
I found it thanks to the advice.  It was totally covered with crud etc.  What a hassle.  Thanks very much.  jt
scouttster
Its there..  I just did this myself.  Looking at the butt-end of the car.  And crawling under the car from the rear you will find it on the LEFT hand side.  It sometimes get filled with dirt and can be difficult to spot..  A good flashlight and an inspection mirror helped me locate it..
When looking at the differential from the drive shaft side, there is a fill "bolt" to the right side, right above the half way casting line, kind of in a "corner".
To remove it you need a 3/8" extension (a three inch works great) on a 3/8" ratchet handle. To put it back on just put the fill cap/bolt on the end of the extension and screw it back in.
When filling, put a pan under the fill hole and pump fluid in until it starts to pour/drip out of the hole/differential.
John Turner
72 Pinto Station Wagon - I removed rear differential cover, drained gear oil, put on new gasket, replaced cover.  I cannot find any way to replace the gear oil.  There is a "breather" hose on the top center of the differential with a small rubber 10" long hose that goes up into a crossmember.  I tried to add oil thru this hose, no good.  Then removed the fitting for this "breather" on the top of the differential housing and my next effore will be to attempt to dribble a quart or so of gear oil thru this tiny fitting hole.  I have to believe that this is wrong.  I cannot find any other fittings on the rear end/differential housing anywhere to add oil.  Just this little fitting with a hose that goes off the top center of the housing.  If they are there I must have missed them.  I may go crazy here.  Help.  Thanks jt
