Clutch pedal needed
Date: 01/11/2024 06:31 am
Date: 10/24/2019 01:43 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 04/24/2018 11:45 am
  • Online today: 367
  • Guests: 146
  • Total: 146
Installing intake manifold on 2000CC engine
Started by djh, February 14, 2012, 12:54:49 PM
johnbigman2011
I read somewhere to put never seize on them?? Said it helps in sealing it and also it doesn't tear the gasket up if you take it apart later.
PintoMan1
i forgot about the center hole  thanks 72pair
1973 pinto runabout
72pair
If the head and manifold surfaces  are both flat then no sealer. If worried about a coolant leak then a little silicone around the center hole.
PintoMan1
i've never used a gasket sealer on the intake or exhaust i have on everything else where you have a liquid going though it or in it helps seal any leaks your intake and exhaust are air no liquids
1973 pinto runabout
djh
My intake manifold is apparently leaking at the gasket so I bought a new gasket and
now need to install it. Besides cleaning the mating serfices should I use any kind
of gasket sealer? Any tips would be appreciated.
Thanks,
Dave
