Date: 07/20/2017 01:23 am
Date: 09/10/2018 10:41 pm
Date: 11/11/2019 03:38 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 03/25/2019 09:02 pm
Date: 06/22/2017 07:19 am
Date: 08/13/2017 02:01 pm
Date: 05/13/2021 05:33 pm
  • Online today: 178
  • Guests: 106
  • Total: 106
Headlight switch on 74 Runabout
Started by dennisofaz, January 27, 2012, 08:45:46 PM
RSM
dennisofaz
Hi,
I used to live in Mesa AZ, moved to Ca in June so that is the reason for the confusion.
Thanks for asking, :D
Dennis
RSM
Thought u might have been in Az looking at your screen name.
dennisofaz
RSM
dennisofaz
Thanks for all the help!  I really appreciate it! 8)
Quote from: dave1987 on January 28, 2012, 01:17:34 AM
For removing the switch from the dash, you need to pull the knob straight off the shaft, there are no clips or anything, they are pushed on. Once the knob is off, a pair of long needle nose pliers will do the job to get to the inside nut/retainer, but a spanner wrench is best if available. Once you have the nut/retainer off the switch ring comes right off and the switch assembly can be pulled inside the dash for removal.
The same procedure for all years and models.
not quite correct....
to remove the knob you need to find the release button behind the dash on the switch... look at your new one and you will see a little steel button... with the knob in one hand and your finger on the switch button... push the button and try to pull the knob..... you will feel when the button hits the right spot as it will sit kinda flush with the switch housing..... the knob and shaft for it will come completely out of the switch housing then and you will be able to easily get to the nut to remove the switch....
dennisofaz
I have removed Ford headlight switches before, but never on one in a Pinto.  I have removed an instrument cluster before on a pinto, but i worry that the plastic housing will crumble from old age.  I guess it is time to zoop it up and to go for it.
thanks for the help! :D
Pulling the instrument cluster is a must when I do anything behind the dash on the driver side. Pulling any ducting helps immensely when doing the switches or even the wiper motor.
The switch plug is easier to remove, without damage, if you dismount the switch first, then pull the plug off. If you do it with the switch still mounted to the dash, you will be wrestling it for a little bit. The connectors are on tight and you have to pull straight upwards.
RSM
They can be a bugger. I did a 76 years ago...they should all be about the same as far as not much space to get at the switch. Have you done a headlight switch on one of these before?
dennisofaz
Has anyone replace their headlight switch on a 74 Runabout?  I just received on in the mail from AutoKrafters and it looks like there is limited access to the switch.  Any help/directions is welcome.  :)
