Automatic Wagon
Date: 06/14/2019 11:22 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 09/02/2021 08:21 am
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
  • Online today: 587
  • Guests: 235
  • Total: 235
another drag racer question
Started by don33, January 25, 2012, 06:59:51 AM
don33
pintoman1972, I don't know how fast it is capable of, it's still in the build stage.  I want to run as close to 10.00 as possible.
fast64ranchero, I am running a stage 3 head and cam also, a holset hx35 turbo, not the ideal turbo, but I already had it.  once I get it running and dialed in the turbo will probably be upgraded.
fast64ranchero
I understand Stinger has a pretty good unit, what are you going to do for head work, cam and turbo? I'm running a stage 3 head and cam from Bo-Port and a 62-1 Turbonetics turbo, not the ideal turbo, but I already had it...
72 old V-8 parts Pinto
73 pinto, the nice one...
don33
will be running a pimp ms unit from stinger performance.
fast64ranchero
Don33 what ECU are you planning on using? just wondering, my 2.3 turbo is built pretty well and I'm only 350whp, figure 2300lbs and 450hp your car should go 10.0's at 135,  so 4.10 gears and a 27" tall tire will put you @ 6900 rpms, I'd run a lower gear and a taller tire, taller tires hook better due to the taller sidewall.
beaner
don33
we are talking a 2.3 turbo motor making 450 - 500 HP.
pintoman1972
Ok Don,
What kind of HP are we talking?
pintoman1972
My question is what et are you capable of running with the car.  That is how fast do you want to go and is your car built to the rules to run that speed.
We build our drag cars to run in certain classes knowing the rules, et and speeds to run.  Knowing that info, we then build the motor, tranny, rear end and install the correct tire size to fit those rules and specs.
Your question of "rear end gearing,  373 or 410 for the pinto ?" does not provide enough info for anyone to give you a proper answer.
So, fill us in on the rest of the story......
As a side note, I will be attending the NHRA GATOR NATIONALS in Gainseville, FL in March to help a few local racers who attend that event.
Dick
don33
the car will have a C4 and use 26 - 28 inch tires wich ever works best.  as far as trap rpm, maby 7000.
v8junkie
Tire dia., final gear ratio of trans, trap speed, is car going to be driven on the street/freeway..all these things play in to what can be acceptable or optimal gears.
73 Pinto Wagon
64 Falcon Futura Convertible
jim72
what does the rest of the gearing look like (ie) gearbox and what do you want for rpm through the traps?
don33
