Date: 04/27/2018 10:28 pm
Date: 10/31/2018 12:04 pm
Date: 10/24/2018 07:41 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 12/24/2016 04:13 pm
Date: 11/14/2019 04:02 am
Date: 06/07/2021 08:14 pm
Crane Cam
Date: 02/26/2018 07:50 am
  • Online today: 529
  • Guests: 413
  • Total: 413
Disc Brake Spindle for 1971-1972 NEEDED!
Started by Abinadi, January 21, 2012, 04:24:43 PM
Abinadi
Thank You, RSM & 71hotrodpinto
I sent a message to Fred.
Thx for the "rave on" it's the best, max-info is better then no-info...
Thanks again,
Bin
71hotrodpinto
Hello, i saw your post. If you cant find any stock stuff to bolt on you might think about a wilwood setup.
If you buy the kit on Ebay it will run you about  $700 or so for the conversion kit. You'd need another master cylinder to match probably another 100 or so. and then unfortunately there is the fact that no one makes a kit to fit 4 lug rotors, let alone 13" wheels. SOoo you'd need another few hundred for some 5 lug wheels which you would most likely want to find as a set of 4. And then you'd need to do something about the rear lugs. The axles could be re-drilled , SIGH!
SO yes that way gets very expensive very fast.
HOWEVER all that being said, the braking performance and stability your daughter will get out of the car will be priceless.
My 71 has manual Stock disk brakes and they require a hard push to stop. IT stops very well for 9in rotors. Its just that it doesn't bother me being a guy. So a firm modulated pedal is no biggy for me.
Sorry to rave on, just that Ive been and am in the stock brake route, and if i totalled up what Ive spent on my brakes in all new parts, just to have factory stopping, id be sick. Ive probably got 300 in them. Rotors, calipers, lines, etc etc. Not to mention that to replace my wheels with 5 lugs would be up there.
SO if you do go stock, look hard for nos rotors on ebay if your very lucky, as replacements are available but they are ridiculously priced. 145 at oreillys auto. They are 2 year only rotors. And no, 74 stock type stuff just doesn't bolt on at all.
I hope ive been help full if not informative.
Good luck!
Robert
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
RSM
Where are you at in Az? Good possibility Fred Morgan may have something.
Abinadi
I am looking for the Disc Brake Spindles and any extra parts for a convertion for the 1971-1972 Pinto!
My daughter is buying her 1st car and has decided on a 1971 Lime Green Pinto, I found her a gem, needs paint and a little work, but would like to get disc brakes on it for a little smoother stopping control. This car has an interesting story. It was bought here in our home town, at the local ford dealership ("was" the old operating ford dealership in the state of AZ up until about 5 years ago) in 1971. It has had 4 owners before her and has never gone more than 45 mile from our small town... and that was maybe 2-3 time; otherwise it has stayed right in our small town. It has 40000 miles on it, the engine was rebuilt, it has 12000 miles on it & the automatic transmission was rebuilt, it has 4000 mile on it! She thinks it's cute...
