Date: 02/25/2017 08:45 pm
Date: 04/07/2021 06:12 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 06/22/2017 07:19 am
Bumpers
Date: 07/06/2018 04:47 pm
v8 springs
Date: 05/07/2017 04:46 pm
Date: 01/12/2019 10:19 am
Date: 02/21/2022 11:11 pm
  • Online today: 489
  • Guests: 328
  • Total: 328
Ok That Was Weird!
Started by blupinto, January 19, 2012, 10:21:50 PM
Yep, that is what is wrong with Nellie Belle. I have to play with the switch to get everything to work.  Hopefully we will be fixing this before Knotts!
 :o :o :o
That is really good advice Becky, my 77 has even done that a time or two & I have replaced the switch.
Quote from: RSM on January 19, 2012, 10:41:05 PM
Good possibility it was the ignition switch. The switch has several sets of contacts to different circuits in the car. It probably didn't make good contact on one or two and you got the glitch that you described. If this happens again jiggle the ignition switch a little and see if everything starts working again. If it does then its switch time.
Becky, this is excellent advice.  My '83 Ford F150 did the same thing from time to time and a quick jiggle of the switch restored everything to normal.
Dwayne :)
Thank you! This was the first time it happened to me. Very weird.
RSM
This morning I drove Ruby RedHot (like usual). She stalled less than a mile away from home (she hiccups and conks out but starts right up). Well this time after she started and we were on our merry way to work I looked at the instrument cluster and saw right away that my 3/4 tank of gas was beyond the E! "That's weird," I thought. When I went to make a lane change I also noticed my turn signal indicators weren't working... and so assumed that the signals themselves were defunct as well. The car wasn't running crappy like I was out of fuel or the battery was shot so I figured it might be a fuse. When I got to work I shut Ruby off and proceeded to look the fuse info up in her owner's manual... nothing really. My headlights and cigar lighter worked, as did my gauge lights and heater. I thought, "Let me test something...", so I turned Ruby on again... and my fuel gauge works again, as does my turn signal indicator. I understand computer stuff can reset after you turn it off... but a '71 car!?! Can anyone shed light on this weird phenomenon? I appreciate it.  ;D
