71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 05/24/2020 08:19 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
  • Online today: 344
  • Guests: 312
  • Total: 312
76 Cruisin Wagon?
Started by waldo786, January 17, 2012, 08:01:26 PM
That car is in North Texas, and has been on Craigslist at least a few times. I like it!
waldo786
Looks good, I like the rims!
robert t
Pic of the 72 I was speaking of.
waldo786
Thank you all for all your info!
Farmboy
It worked out good on my 74, good luck
74 Pinto Wagon
71 Runabout (parts car)
My understanding is that the body structure of the wagon area was carried over from year to year. Case in point - I had a regular '79 wagon, to which I attached the panels and created a panel wagon much like you desire.
You first need to remove your original side windows and any trim around them (if present). The panels are attached to the body with a number of "tabs" on the panels through which screws can be driven between the pinch weld areas of the original window frames and the panel tabs. The panel surfaces need to be sealed against the car with 3M body seal.
This is a general guideline; I know thah there are other factors (like gutter extensions, interior panels, etc.) that also are part of making these panels 100% "factory appearance", but the attachment of the basic panels themselves to the body is pretty straightforward.
Good luck!
robert t
Not sure of all the putting them in,but yes,there is a guy here locally with a decent looking 72 that he put the inserts for the Cruising Wagon on/in.
waldo786
I see that Ford started making the Cruzin' wagons in '77.  Can my 76 be adapted with the panels to make one, and what all needs to be done?  How are these attached on the 77 and later?  Can I just put these panels over my windows?
