Date: 02/18/2017 04:41 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 10/27/2018 03:30 pm
Date: 03/06/2019 06:40 pm
Date: 05/15/2022 11:36 am
Interior Parts
Date: 08/07/2017 03:59 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 02/04/2018 08:26 am
  • Online today: 224
  • Guests: 165
  • Total: 165
1979 2.3 intake manifold
Started by lefty, January 17, 2012, 06:48:50 PM
Generally the 70's 2.3 has oval shaped ports while the 80's efi 2.3 use a D shaped port.  The 90's efi manifolds on the dual plug heads are too different to be of use.  I believe the 80's efi manifold will bolt up to the 70's 2.3 head (may need to drill/tap a hole or two).  The port mismatch is not ideal for getting the last increment of power but will run okay (my 87TC had a oval port head retrofitted).  Racer Walsh advertises a adapter plate for the efi manifold to use your 500cfm two barrel carb.
http://racerwalsh.zoovy.com/product/RWA1232A_ALUM/adaptor-efi-2bbl-1-Alum.html
lefty
any chance anyother 2.3 manifold would work? I heard a bottom half of a 2.3 fuel injection intake would work????
johnbigman2011
Lefty, there is a nice Esslinger intake on ebay right now. Buy it now price of 150.00. Check it out?
waldo786
Summitt Racing sells aftermarket offenhauser ones for these engines.
lefty
question: what other 2.3 manifolds with fit my 1979 2.3  I am running a 2bbl 500cfm carb have spacer plate etc--my current manifold is cracked... Will a 2.3 fuel injection bottom half of a mustang or t-bird work(if so what years)??? Appreciate help and thanking you in advance...
Lefty
