cam pulley
Date: 05/30/2018 04:56 pm
Date: 03/05/2017 03:27 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 08/13/2018 02:46 pm
Date: 01/18/2017 05:35 pm
Date: 03/17/2019 10:15 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 10/11/2019 11:13 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 178
  • Guests: 128
  • Total: 128
She's REALLY developed an appetite
Started by slowride, January 16, 2012, 08:51:25 PM
slowride
She's button up, leak checked and test driven.  ;D The head wound up needing all new guides, exhaust seats, cam, lifters and followers. It has about 10 miles on it and I feel good about the cam choice. There's noticeably more low and midrange torque, but we'll see how it's manners are on the freeway tomorrow. Less pedal is required to accelerate or climb a hill than before, so hopefully better gas mileage follows!
Would have been interesting to see if the header helped with a bit more cam....
slowride
I'm not so concerned with zinc content with stock springs. I'll run some eos on startup and change at around 100 miles.
Every time I hear of others upgrading their cam I want to put my Crane Cams Blue Racer back on my 78.....I think that not knowing what type of oil is safe is what's holding me back. That's the whole reason why I swapped to a roller setup.
slowride
The machine shop I've used for decades is shutting down next month, so I decided it's time for him to freshen up the head on my 2.3. Pulled it off Saturday, and got it to him this morning. Called after he started tearing it down to get the news. "Why are you sending me junk heads?". Uh-oh, I've been down this road before. "what now" I ask. He starts reading the list.....
New cam and followers- worn and is grooving the followers
One lifter won't come out- New lifters, no big deal
BUT he says the valves and cam bearings look good, so "what do you want to do?". I figure as long as it needs a new cam I might as well step it up a little. "I HAVE to have this buttoned up and drivable by Wednesday morning, so what can you do cam-wise?". He tells me what my options are, so considering I just removed the header, I'll go up one step and go with the Comp Cams 252H. The specs say it's good from 1000-5000rpm, with more torque and better mileage. Should be a decent cam since I do mostly freeway and it's an automatic. And since the head and exh manifold were off, I replaced the starter.
I think I may be able to re-use the radiator cap..... :o
