Date: 07/17/2018 09:49 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 08/08/2017 01:44 pm
Date: 12/04/2018 07:40 pm
Date: 03/21/2017 07:47 pm
  • Online today: 228
  • Guests: 166
  • Total: 166
Electrical Question
Started by 77pintocw, May 03, 2005, 07:20:38 PM
77pintocw
Quote from: Pintony on May 06, 2005, 11:21:01 PM
Hello 77pintocw,
Do not spend money on an EGR valve.
I have 80+ NEW Ford units that need a good home.
Please contact me before purchase.
5.00 + shipping
Remember these are noS Ford pieces.
Hey Pintony:
Send me your address when you get time.  My e-mail is c2804gem@hotmail.com
Thanks!
1977, Pinto Cruising Wagon, White with Blue Graphics
77pintocw
Hi CHEAPRACER:
I sent my original carburetor that was destroyed by the Ford dealership to
Pony Carburetors, Inc. in Las Cruces, NM.  They did a fantastic job restoring
it back to the original condition.  I have not put it back on the engine yet,
but they said they actually tested it on an engine and it works just fine.  I will
let you all know what happens.
Thanks for the input!
CHEAPRACER
I've also seen NOS carbs on ebay lately.
77pintocw
Hey Pintony:
Thanks for the offer.  My e-mail is c2804gem@hotmail.com
Also, I read that you are a parts dealer.  Do you have a list of
the type of parts or do you have a website?  Or do we just
give you a call with what we need?
Greatly appreciate the help!
Hello 77pintocw,
5.00 + shipping
Remember these are NOS Ford pieces.
CHEAPRACER
  Another "no respect for the Pinto" story. They probably laughed and joked about it while working on it.
No need to just change an EGR valve, just look at it, make sure it's not stuck open and see if it holds vacuum by sucking on the hose with something. My guess would also be a vacuum hose and or carb issue.
77pintocw
Good suggestions.  I will replace the egr valve and oil.  I know the vacuum lines are hard and have
not been attached to the right locations.  That's why I asked for the vacuum line diagrams so I
can do it myself.  In fact, the reason I took it to the Ford dealership was I didn't have the time,
what a mistake.  Now, I get to spend the summer fixing the problems that they created.  However,
I will get to know my Pinto better. :)
dirt track demon
7.  Metal tube attached to manifold damaged by corrosive compound.
8.  Corrosive compound sprayed in engine compartment that removed the blue paint from the rocker arm
     cover and manifold.  In fact, it removed the paint from the Motorcraft oil filter.
In light of what you said here It sounds like egr valve to me,  whatever they sprayed probably glued the egr valve open.  I would strongly recomend changing the oil, too.
Take these morons to the cleaners.
Fomoco's biggest achievement:
The PINTO!!
Fomoco's biggest mistake:
wagonmaster
In California, unless you say otherwise, they have to save all the old parts taken off. If they don't, that can open them up for a lawsuit and, if it happens too many times, they can have their license yanked!
From what you've described, it is very possible that some of the smog vacuum lines or valves were damaged. Unless all the original vacuum lines were replaced, they could be hard and brittle and get a crack in them that may not be noticed causing a vacuum leak and/or a vacuum operated valve to not function properly or at all.
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
77pintocw
Hi:
Believe me, I have the highest respect for competent auto mechanics.  However, this person that worked on my Pinto does not fix in this category.  Here is a brief summary of some of the things that this person did to my Pinto.
1.  Suction line accumulator was removed from the A/C and thrown away.
2.  All original screws holding the air duct system were taken off and thrown away.
3.  Original like new carburetor completely destroyed and turned into a rusted mass.
4.  Original like new carburetor tag ripped off and thrown away.
5.  Original like new aluminum air cleaner housing was destroyed by being hammered on and cut with tin snips.
6.  Corrugated tubing attached to the air cleaner housing removed and thrown away.
9.  Original tower heater hose camps removed and thrown away.
10. The original 1977 carburetor was removed and replaced with a 1979 rusted out Pinto carburetor.
All of this work (what a joke) was done without my knowledge and/or approval.  Also, I explicitly told them not to discard any parts which was completely ignored.
Needless to say, I am very upset over the damaged that was done to my pristine Pinto.
CHEAPRACER
 Being a mechanic myself, please don't accuse until you determine what is acutually wrong. They could have very well screwd something up or they could be telling the truth. I took my 88 Stang in for an ignition switch recall and when I drove it back home the door wouldn't open. It wasn't their fault. It's an old car, have it checked out somewhere else and if they screwed up then take them to small claims. Trust me, I know a "certified" mechanic that I would't trust putting gas in my car so I really don't stick up for too many mechanics.
wagonmaster
From what I've seen so far, it almost sounds like a vacuum leak problem. I would tend to agree with you that a carb rarely goes bad instantly, unless you get some bad gas or end up with water in the gas. If they were converting to R134a, as you stated, did they disconnect any of the AC hoses in the engine compartment to replace the seals? If they did, maybe they broke or pulled off a vacuum line without realizing it. The electronic distributors of those years rarely give any trouble. Back when, the control modules would cause the engine to die suddenly. Usually all you had to do was turn the key off for a moment and then restart the engine and it would be okay again for a while. I haven't heard of any replacement control modules doing that for quite sometime.
Brien - wagonmaster
'85 LTD LX
77pintocw
Yes, I agree, not having all the information and details makes it very difficult to guess at what might
have caused a problem, sorry about that.
How about if I approach it this way.  My carburetor is a Motorcraft (Holley) 5200, 2 bbl, on a 2.3L
engine with factory A/C and manual transmission.  The carburetor was running perfectly.  The Ford
service department says it just stopped running correctly and I believe there was nothing wrong
with the carburetor and it was an electrical problem.  Have you ever experienced or heard of a
carburetor running perfectly and then just all of a sudden start running poorly during normal operation?
From my experience cars suddenly start running poorly for three main reaons, bad gas, vacuum leaks, or an electrical problems.  Carburetors tend to gradually get worse over time and not just suddenly start acting poorly.  If I am wrong in this thinking please let me know.  I am not expert but do need to be educated on the subject before I go to court.
Greatly appreciate the help.
Thanks!
dirt track demon
This is not an easy question to answer,  is the car running right yet?  The high voltages could cause damage to the duraspark ignition module, the coil, the pickup in the distributor,  various electric emissions components.
  Do you know anything about working on cars yourself?  Have you looked at your spark plugs.  Sometimes you can pinpoint your problem by how they look.  High ignition voltages could have ruined the electrodes.
  We would need to know what all the dealership did to your car while "trying to fix it".
  Also, is the egr valve still on the car, sometimes they stick from age and deposits, and will cause a car to do strange things.  Without being able to look at your car and hear what it is doing, it is very hard to answer your question.
  If you know what the egr valve is and where it is at, if you have a hand operated vacuum pump, hook it up to the egr valve vacuum fitting and start pumping and see if it moves,  there is usually only about 14 lbs of vacuum, so if it takes more than that to move it it is probably defective, if it doesnt move at all, it might be stuck open,  then try pushing it closed.
  As far as the choke goes, if it isnt closing right, it wont run right until it warms up.  It it isn't opening right it will start up ok, but not run right trying to drive it.
  You can start the car, get it warmed up to operating temp, and wire the choke in its open position.  Go for a short drive if it wont run this way, or has no power, the problem lies elsewhere.
  What kind of carburator is it.  Different carbs have different problems associated with them.  I cant help you much more than this without furthur info.
The PINTO!!
77pintocw
Hi:
I need to provide more information on my question about the electric choke.  My local Ford dealership’s service department has damaged my 1977 Pinto by misdiagnosing a problem.  I took my perfectly running 1977 Pinto in to have the A/C converted to the R134A refrigerant and by the end of the day the service department tells me my car is no longer running properly.  After many months and much damage to my car I am forced to take the Ford dealership to small claims court to pay for the damage.  The service department claims my carburetor just stopped running correctly and as a result they completely destroyed my original carburetor.  I believe there was nothing wrong with my carburetor and that a malfunctioning voltage regulator caused my car not to run properly.  Can anyone tell me if a malfunctioning voltage regulator can cause my Pinto to run extremely rough?  By the way, the Ford dealership charged me $616.00 to destroy my Pinto’s engine.
Thanks!
dirt track demon
You could also check the wire to the choke with a voltmeter to see if it is getting power to the choke as well.  Have you replaced the voltage regulator yet.  As far as the 19 volts goes,  it might have damaged the duraspark module, coil, or possibly the plugs.
The PINTO!!
CHEAPRACER
 My '74 choke was tied into the alternator and only sent power to the choke when the engine was running. If you fried the heat coil, it might be staying on choke even when the engine is warm. Take the air filter assembly off and see if it's staying closed. You can shut it off by rotating the choke housing, after loosing the screws, until it is fully open. Of course that will be just fine here in Ca. but maybe not in colder climates.
77pintocw
Hi:
My question is about a manual, ‘77 Pinto, 2.3 L, A/C with the original fully electric choke on the carburetor.  If for some reason the voltage regulator were to malfunction and allow the electrical system to put out high voltage (19 volts to the battery), could this cause the fully electric choke not to work correctly, which would in turn cause the carburetor to function improperly and make the engine run extremely poorly?
Thanks!
