Need Interior Panels
Date: 07/09/2018 04:59 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 04/27/2018 10:28 pm
Date: 02/16/2019 10:46 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 01/23/2023 02:22 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 01/21/2023 04:19 pm
  • Online today: 600
  • Guests: 241
  • Total: 241
Pinto use shims
Started by pintovol, January 04, 2012, 07:40:42 PM
pintoman2.0
Pintovol,
If you have never pulled a wheel before, some are splined really tight or might have some rust in them. When you get to the point where you can't turn the push bolt any farther, don't keep cranking, you will only break something. Rap on the push bolt and it will help to loosen the splines. It might pop loose on the first hit or you might have to tighten it up and hit it again a few more times.
P
Quote from: slowride on January 07, 2012, 12:00:09 PM
While this is the textbook way to center, the real world often has a different idea. I just replaced the rack in my 74, and centered the rack between locks. When I connected the coupler, the steering wheel was off about 75 degrees. I could not adjust the tie rod ends enough to center the wheel without adjusting one or the other out further than I was comfortable with. After alignment (the shop didn't center my wheel either), I just popped the wheel off and centered it. Since there isn't an index spline, it'll go back on in any position. Rack centered, wheel centered, down the road.....
hence the use of the word 'proper'
as you experienced, the 'real' world may have other ideas.
slowride
Quote from: Srt on January 07, 2012, 10:28:39 AM
the proper way to center a steering wheel is to adjust the tie rod ends (outers) accordingly. if the wheel is canted to the right when you are traveling in a straight line that means the wheels are pointed to far left.  you need to adjust the tie rods to pull/push both front wheels to the right.
keep doing this little by little adjusting the same distance on each side until the wheel is straight and then double check the toe
Quote from: pintovol on January 05, 2012, 07:43:33 PM
well i took it to another shop, they said their machine went back to the 40s
they were able to line it up..said the camber was out 2 degrees but it adjusted. and every thing was in the "green light" OK
don't know what was wrong with the other shop
but he said to get my steering wheel back to where it needs to be I need to take it off and put it back on
instead of it being straight across at the 1 and 9 o'clock positions ..its at 5 and 11 is the wheel hard to get off?
v8junkie
Sadly the cars that are older than the people using the machines at the tire shops get misdiagnosed because they don't have the experience to know how to adjust them. Glad you found a shop that figured it out.
73 Pinto Wagon
64 Falcon Futura Convertible
Mike Modified
It is NOT fully aligned until the steering wheel is straight.
A shop should be smart enough to lengthen the slots so that perfect align is possible.
slowride
You will likely need a puller, but it's pretty straight forward to do. Glad you found a shop that actually knows what they're doing. They should have centered the wheel as part of the alignment though.
pintovol
pintovol
he said the drivers side was to far out...hell i dont know ;D
slowride
Find another shop. Camber is easily (and obviously) adjustable. They must be great at aligning Hondas.....
pintovol
he said the toe was good, but couldnt adjust camber..not really sure why,,,said he saw no where to adjust i think
slowride
We would need to know exactly WHY it couldn't be aligned to determine what the cause is. Was it caster, camber, toe-in?
pintovol
well i took it to get lined up and they said they couldnt line it...said to out of wack couldnt adjust  >:( :o
but it drive good just a SLIGHT pull to left
Mike Modified
No.  The upper A-arm mounts with two slotted holes which provide sufficient adjustment for alignment.
pintovol
Does a 1976 use shims ti lone the frontend up
