Date: 08/08/2018 12:26 pm
windshield
Date: 04/14/2018 08:53 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 10/05/2017 02:26 pm
Date: 12/31/2017 11:14 pm
Date: 02/28/2018 09:33 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
  • Online today: 531
  • Guests: 212
  • Total: 212
stiffening a sway bar with angle iron?
Started by carbomb, January 01, 2012, 07:02:31 PM
PintoMan1
also as far as i know the bars are hollow!
1973 pinto runabout
postalpony
Hi carbomb
1st don't weld on your swaybar. They are heat treated to effect torsional forces, & if you
weld on it the heat from the arc may cause the bar to break. This is just my opinion from
my 45+ years in industrial maintenance.    Dick
Now all we do is HAUL!
RSM
carbomb
I know you can buy bigger sway bars for pintos but i would rather spend my money on other things! I was wondering if there is anything very wrong with welding angle iron on the straight part of a sway bar? That would be where all the torsion and twisting occurs so if you welded a little reinforcement to it it should make stiffer and handle better. Right? I have coilovers on the back and it stays pretty flat just the front sway bar needs to be stiffer. We have a 220 mig so we could really melt it in and get good penetration. Just woundering if anybody has tried this or has any reasons not to.
