Great Cruise wagon
Date: 12/17/2016 03:39 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 02/26/2017 03:22 pm
Date: 05/22/2018 01:54 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
postal pinto
Date: 06/03/2020 09:31 am
Date: 10/11/2019 11:13 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Online today: 600
  • Guests: 376
  • Total: 376
front brake lines
Started by 82expghost, December 19, 2011, 10:27:58 PM
82expghost
they are the same brake lines, mustang ii and pinto both use the same doorman part number h80013, both 16.75, im guna try bending and relocating the hard lines to make it alittle better, also where it comes out of the caliper the line rubs hard on the ball joint nut, i mite rethread the caliper to accept a banjo bolt and fitting and find new longer lines, i wll post it with pics and part numbers to help every one else
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
The link below suggests using the flex lines out of a Mustang II for this swap.
http://www.fordpinto.com/index.php?topic=13031.msg86104#msg86104
82expghost
well my nappa cant make brake lines so im still stuck still in the water, i cant be the only one with these problems, any help?
82expghost
im goin to go to napa if they can make them, but i also need the crimpped  part on the male end to be shortened because it sits right against my ball joint nut, does any body else have this problem? if so, how did you fix it? im guna go ahed and have lines made, also, how do you fix its bump steer after you lower it?
Your soft lines are too short? Go to a NAPA store and have them fab up a new set of lines. Just bring in the old lines and have them match the fittings and crimp on a longer soft line...Or go to any Big Rig service place and they should be able to fab some up....
289Wagon
 If you can't locate the hoses you need you may want to check out this place.
Brake Hoses Unlimited,  a search will probably take you to their ePay site, they do have a web site but it's a pain to find it. I found it easier to just E them, goodbrakes@brakehoses.biz
They made some custom hoses for me & I was pleased with them. They are DOT approved & made here in the USA not china.
RSM
"Custom" brake lines aren't really expensive. I've had some made up at a local shop before. You might be able to go to a local parts house and see if they will let you look thru hoses or help you find what you need.
82expghost
I just recently put landrum springs on the front with race shocks and 2inch drop spendles and new brakes, but my brake lines are too short now, they are 17 long, i need about 20, any help? or am i stuck buying custom lines?
