Date: 09/12/2018 12:33 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 12/31/2017 09:03 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 03/13/2021 12:57 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 01/10/2022 03:41 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 452
  • Guests: 362
  • Total: 362
78 wagon 2.3 power steering presure hose removal
Started by tonij1960, November 12, 2011, 03:36:24 PM
ToniJ1960
 I tried to get the top part loose with a 5/8 line wrench but I think I needed a metric one it didnt fit real tight. I found someone to do it for $30 so it wasnt too bad. I think I could have done it if I had the right tools. Its supposed to be 5/8 I thought. I started rounding the nut on top so I quit right away.
i just replaced my hose last fall it was not to bad  but if you are getting a puddle it may be the pump  front seal. after my hose went on a drive i ended up wearing out my seal on the pump. i tried to just replace the seal, that did not go so well so i replaced the pump and changed the resavor. that was much harder than  changing the hose but i alsohave ac on my car. with paticence  you will get it fixed.
ToniJ1960
Is this something I can do easily? I have some flare wrenches, but looking up under the car it looks like there will be some things in the way trying to get to the bottom end.
Any advice or suggestions? If I cant see it well or get to it easily I tend to give up.
Also if it leaves a good sized puddle under the car where its parked,is it less likely to be the hose and more likely the rack leaking?
The pressure hose was leaking at the top about 6 months ago and had someone look at it he just replaced the o ring at the top of the pressure hose. It stopped leaking for a while, so Im assuming its likely the lower o ring gone bad since they probably would go about the  same time. But Im assuming, and afraid it might wind up being more major.
