13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 07/17/2018 09:22 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
72 Pinto
Date: 03/07/2019 12:07 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
  • Online today: 295
  • Guests: 204
  • Total: 204
Throwout Bearing....Zerk Fitting or not?
Started by sagesunrise, November 05, 2011, 08:23:16 AM
You dont want a zerk on a throwout bearing. The excess grease would end up contaminating the clutch & causing headaches.
sagesunrise
I'm thinking my throwout bearing is bad. Going to pull tranny and replace all of the parts of the clutch including the pilot bearing. Also doing a little fixing of the gearshift and corresponding shaft. Have a couple things to toss out to the group. Can I get a zerk-fitted throwout bearing for my setup? (1973 2.0 motor and tranny) and does anyone know the proper name, and possibly have a connection for, the "cap" that screws on the top of the tranny where you would access the shifter parts? It seems like it is a plastic open "ring" with little flanges sticking off of it like a sun. If I were to pull the shaft that the shifter rides on, I'd need to remove this ring/nut first. Wondering what it is called and if anyone has a spare. Thanks for any help.
Tiffany Morrison
'71 Pinto Sedan 2.0, '51 Willys CJ3A, '75 Ford F250, '70 Ford Maverick, '68 GMC Value Van (aka the Hippie Van), and a 1947 Flxible Clipper RV conversion Bus, 1953 Ford Jubilee Tractor, 1969 VW Baja Bug
