Date: 08/08/2017 01:44 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Built 2.0
Date: 10/07/2018 05:27 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 08/30/2021 03:20 pm
Date: 08/08/2018 12:26 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 584
  • Guests: 517
  • Total: 517
Which rear leaf spring rate for a V8?
Started by gearhead440, November 03, 2011, 07:14:45 AM
82expghost
go big, i have the 150s, its stiff, but so predictible around the turns, lowers your car just to warn you
98 taurtus, now in heaven
77 pinto, weekend warrior
92 grand marquis, daily
go for a matched pair.  it makes replacement easier in the future.  also, as for the 125# for the passenger side & the 100# for the drivers side;  does the battery weigh more than you do?
gearhead440
After much searching, I've decided to go with 100# on driver's side and 125# on passenger's side especially considering the battery will be trunk mounted.
gearhead440
 My 1980 Pinto needs new leaf springs.  I'm swapping in a 302 and T5 with a 9" rear and was wondering which leaf spring rate to choose.  Speedwaymotors.com lists 3 spring rates:  100#, 125# and 150#.
http://www.speedwaymotors.com/Landrum-Pinto-Mini-Stock-Leaf-Springs,3563.html
The vehicle will be a daily driver and will use a front sway bar, either stock or 1" diameter depending on oil pan clearance.
Thanks.
