1974 Ford Pinto
Date: 10/16/2017 10:45 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
74 pinto
Date: 09/11/2016 06:32 pm
74 pinto
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
  • Online today: 1,106
  • Guests: 136
  • Total: 136
Cruise Control?
Started by hoots, April 28, 2005, 06:52:55 PM
pintowgn73
it wouldn't be too hard to transplant the factory cruse from a tbird when doing a 2.3 swap. if you were transfering all the drive components over already it would just be a matter of making sure that you transfered the cruse control components after the swap was done. I'm going to have to look into this when I get around to doing my swap.
hoots
I understand, I used to be on the inside of the stereo industry. Thanks anyway though.
pintoman
Hey Hoots check with JC Whitney they carey some cruise's.With the company policy it;s hard for me to buy from them.There afraid that i might make a proffit and they wont.
This was a good question. I plan on installing a cruise control on my Pinto as well. I plan to install it my self. If I am going to regular the Pinto meets in the future then I,m sure as heck not going to be pushing a gas pedal for hours on end. I like the magnetic pickup on the driveshaft thing.....it sounds like an active system. I will be noting input on this subject.
hoots
That's the brand that was quoted to me, with the magnet kit and a replacement turn signal arm. Any chance you could get me a better deal for the parts?
pintoman
Ok, if you realy want a cruise control go to your nearest after market shop and ask them.I install cruises for a living.The best after market cruise is the Rostra electronic kit,part number 250-1316.There are several different arms that can be added.You will also need a magnut kit or a signal generater for sensing the speed.It works great for most cars.I used to have one on my car,but it didn't work to good with the turbo,it surged to much.The company i work for charges about $280 installed.Well good luck.
Just use a stick wedged between the seat and the gass pedal. ;D ;D ;D
Poison Pinto
I think I saw a '76 Bobcat with a factory cruise on the turn signal arm. If so, you might be able to use a stock Ford application transplanted in your Pinto.
Just a thought.
hoots
Has anyone added a cruise control to your Pinto. Was wondering what type was used. I found one for 250.00, it has the screw in type turn signal controls that replace the existing lever. The sensors are 4 magnets on the drive shaft with a pick up sensor.
Years ago you could get a part that goes between the speedo cable and speedo  gauge.
Any other suggestions. ???
