Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 10/24/2018 07:41 am
Date: 02/28/2018 09:37 am
Date: 08/05/2018 01:58 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 04/12/2017 08:15 am
Date: 10/15/2017 10:03 am
  • Online today: 624
  • Guests: 602
  • Total: 602
install dash cover with dash removed?
Started by spyville, November 02, 2011, 12:43:36 PM
I would think you would be fine, dash pads are pretty stiff when removed from the dash and in my experience fit right back on without tweaking. Follow the instructions that come with the dash cap, silicone around the outside edges only, not the entire surface of the dash pad. lightly sand the areas you will be putting the silicone on, cut out any raised areas of the dash pad and allow an overnight dry time for the silicone...
to see how much your dash pad will flex when reinstalled... lay it back on the dash in the correct position, hold down one side of the pad lightly but firm. Now push down on the other side and see how much it "teeter-totters" If it doesn't have much play or slop, there shouldn't be a problem... if it "teeter-totters" and lots of play... you may not want to risk it.
spyville
That was one of my concerns. It does not seem to arc much when its off and the cap sets on it ok. But unless someone knows better I'm going to try it. It will make painting it easier as well.
Proud Owner of the hardest working couch in America.
I haven't but have thought of it before. I don't see why it wouldn't work though. The only thing I would be concerned about is the cap separating in some spots when the cap is reinstalled and flexes some.
spyville
Any one ever install a dash cap with the dash out of the car? Any hints?
Thanks
