78 wagon instrument y
Date: 04/30/2018 07:41 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 08/05/2018 01:58 pm
Mirror
Date: 04/15/2020 01:42 pm
Date: 06/24/2020 06:12 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 12/26/2016 04:29 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
  • Online today: 515
  • Guests: 443
  • Total: 443
Carb question
Started by Starsky and Hutch, October 17, 2011, 07:38:07 PM
JohnW
I believe both of those years used electric chokes.  There may be a difference in vacuum lines - like the electric choke carbs have a vacuum line running to the choke as well when the water ones don't.  If the stock carb used a water choke, you can reuse it on the other carb or reroute the lines and use the electric choke.
You should be fine than, check to see what model carb's you have . You should have the 5200 and it might just be jet differences to worry about...If they are 6500 you might have problems...Take the carb into a good parts store and they should be able to help you.....Note while I said model 5200 that is the Weber Model Number you need to run the Ford part number that is on the tag of the carb.....
i live in canada and the car was built in st thomas ontario
What state are you in ? It should not unless it's a Calif car. The smog cars had different carbs...
Does anyone know if the 78/ 2 barrel carb for the 2.3,,,will fit and work with the  2.3 77 model year ?
