Date: 07/01/2019 03:17 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 05/13/2021 05:33 pm
Date: 08/06/2021 02:23 pm
oldskool787
Date: 02/12/2017 12:42 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 04/12/2017 08:15 am
  • Online today: 394
  • Guests: 300
  • Total: 300
Can anyone take a quick measurement for me tonight?
Started by JohnW, September 28, 2011, 07:49:48 PM
JohnW
From what I can find, like here for example: http://alternatorparts.com/wire_size_chart.htm is that 4 awg is about normal for that amperage.  A little overkill isn't going to hurt anyways.
I have a 140 amp Tuff Stuff for the V8 & was only planning to use 4ga. to the solenoid & 2ga. to the trunk mounted battery. I was also going to use 4ga. to the MSD mini starter.
I was thinking THAT was overkill. 4ga. for 100 amps seems like mega-overkill to me. I would have thought 6ga. to be plenty. JMO
JohnW
Going to a 100 amp Powermaster.  4 awg is recommended from what I can find.  Not too much more expensive than thinner wiring, and I'd rather go on the safe side.  I'll also have minimal voltage drop and the wiring won't get as hot.
RSM
How big of an alternator are you planning on running?...
JohnW
No, I'm going to a heavier gauge for the higher amp alternator.  Thanks though.
RSM
It's 6' if you measure straight around. 8' would be good to order. You wouldn't happen to need the connector and stuff going to the alternator would you? I just removed all of that since my alternator is now on the other side and I have to rewire it anyways. If you would have posted this 2 days ago I would have removed the entire length and sent to you but I cut the connector off and rerouted the original wire. Let me know.
JohnW
I was planning to order 10 feet, just wanted to make sure that wasn't too little.  Thanks.
I just restored my wiring harness for reinstallation into my car, so I got  a good feel for the length. I would guess 8 feet should be plenty with some excess, it's probably more like 6 but don't get too little. Good luck.
JohnW
My car's 80 miles away and I want to order power wire tonight.  Anyone with a 2.3 that can measure from the stock alternator power connector straight over to the driver's side fender, along the fender and firewall, and to the solenoid post?  I want to make sure I get enough of the 4 awg wire and I don't want to get too much.  Basically planning to run it around the edge of the engine bay.
