SVO SWAP
Date: 03/15/2018 03:12 am
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 03/13/2021 12:57 pm
Date: 02/03/2018 11:28 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Date: 04/14/2023 06:15 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 1,972
  • Guests: 129
  • Total: 129
posi rear end 3.55 for 6.75.
Started by americanpintobean, September 01, 2011, 06:24:33 PM
i experienced great longevity and no problems to speak of in terms of durability with the 6.75 in my 71.
it took the abuse of street/strip drag racing & a bit of autocross/roadracing over a 'career' lasting about 60 thousand miles.
the ratio was 3:55. an 'open' rear end (no posi) and the ONLY thing that ever went wrong was a u-joint / driveshaft failure that bent the pinion shaft at about 50 thousand miles during a street racing contest.
the rear end was behind a boosted 2.0 that was not babied at all.
that said i was always on the lookout for a lower gear but (in those days) i didn't want the weight of a big 9" to take advantage of available ratios. not to mention the added expense of wheels/tires and what not.
i drove it hard but i respected it and it lasted a long time
Bruce is right, the 6.75" axle is very weak. With gear ratios like you are talking about I would assume you are using a turbo 2.3 or a V8, and the stock 6.75" axle will not last long behind one of those, even with light throttle on a V8, it's just to much power.
Again, Bruce is right, the 8" from a V6 Pinto or Mustang II would be a better choice and you would easily be able to find parts for it. I run a Mustang II 8" axle with 3.00 gears behind my stock 2.3L and stock 4spd FOG transmission and it's great. Parts are readily available to!
baflinn
The 6.75 is pretty weak if you're going to be doing any kind of aggressive driving with power. Probably better to look for a rear from a V6 pinto wagon. I forget what size it is - 8" or 8.5" someone here will correct me but that will be a bolt on and gives you room to work with more power. -BruceF
Liquidating all Pinto related parts.
Current list can be found here: http://www.flickr.com/photos/bruceflinn/8007178278/in/photostream
americanpintobean
like the '60s econolines? Will a 7.5 rear end fit without any suspension modifications?
look into early econoline rear axle stuff
americanpintobean
Can anyone help me out with this?  I am looking for a posi for the 6.75 with 3.55 or 4.11 ratio.   I just need the gearing to put in the one I have, which is non locking 3.08 ratio in a 6.75.
