78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 02/28/2018 09:33 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Date: 03/06/2017 01:19 am
Date: 09/03/2018 08:58 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
  • Online today: 548
  • Guests: 203
  • Total: 203
No more points
Started by johnbigman2011, August 29, 2011, 05:57:33 PM
RSM
I found one place that has the PerTronix for about $70 and they reccomend replacing the coil. If you use a coil with the wrong resistance it will burn the PerTronix out.
From all the research I've done on these kits, it seems really simple to install, and as RSM stated, it's just like changing a set of points but minus the condenser. From what I've read, you can even use your original coil!
My 73 Station Wagon came with a Crane Cams Fireball XR700 points eliminator kit. I haven't played with it since I swapped it out for Points, but I think my issue is due to a missing tab on the optical shutter wheel. Unfortunately it's about $50 to get a kit with ALL of the shutter wheels and not just the one I need. I can't bring myself to pay that much when I don't even know if the control module is any good. I won't play with it until I get some other bugs on the car figured out.
RSM
They are simple to install. Almost just like replacing a set of points. The instructions are very detailed so installing is easy.
johnbigman2011
Thanks RSM for the info. Is it hard to install and is the kit complete with everthing that is needed?
RSM
I've use PerTronix systems on several different vehicles with very good results. Part # 1847V is the number for 2.0 engines. The website doesn't give a price but they aren't that expensive. http://www.pertronix.com/default.aspx
johnbigman2011
Is it possible to remove the points and condenser on a 2.0 distributer and go to a aftermarket electronic ignition like they are selling on e-bay?
