Date: 08/26/2018 06:35 pm
Date: 07/30/2018 04:32 pm
Date: 03/30/2021 12:29 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 02/28/2024 02:07 pm
Date: 08/13/2018 02:46 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
  • Online today: 309
  • Guests: 345
  • Total: 345
V6 to 2.3 Swap
Started by lugnut, August 14, 2011, 04:44:58 PM
lugnut
Fast34, Thanks for the reply!  No point in removing them if they are the same, just a waste of time and effort!  I noticed the alternator wiring, but electrical work is my specialty, so no problem there. I knew that someone would answer my question eventually.
thanks again!
mike
fast34
They are the same if you haven't found out... Alternator wiring is on opposite side between those two as well.
lugnut
I would like to know because someone wants to buy the body engine brackets from the V-6 car, but I thought that they are the same. By eye they look identical.
thanks,
mike
lugnut
I just removed the 2.8 V6 and auto trans from a 78 Pinto wagon, and I plan to put in a 2.3L and 4 speed from a donor 78 hatchback. I can see that the piece that attaches to the engine blocks are different; the rubber insulators look to be the same- confirmed at rockauto dot com.
The question is: are the motor brackets that attach to the body the same for a 2.3 and V6?
thanks!
mike
