1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 07/17/2018 09:49 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
76 drivers fender
Date: 07/20/2018 08:24 pm
TWM Intake
Date: 08/15/2018 08:20 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Date: 05/28/2017 03:20 pm
Date: 01/24/2021 07:54 pm
  • Online today: 529
  • Guests: 456
  • Total: 456
Steering intermediate shaft removal
Started by morpheus256, August 11, 2011, 06:37:43 PM
Your welcome and thank you.
If you can, try to turn the steering wheel till the stud is facing up and punch it from the top.  If you have a long enough dowel you should be able to reach it, maybe.  That should save you from having to crawl under the car.
morpheus256
Thanks Tigger, I actually took the rag joint apart to disconnect the lower half, and left the rack shaft attached to the coupler.
The brass punch/wooden dowel was the tip that I needed to get the upper off the steering column. my new problem is dragging my fat  :showback: under the car and finding the room to get a punch/hammer under there with all the grease and oil sludge the engine's been spilling everywhere :)
BTW: Thanks for the Brake/Clutch Peddles on eBay, they arrived perfectly I'll leave you some feedback later tongiht!
Bone stock 79 Runabout
Remove the bolt completely from the end that bolts to the rack shaft.  I believe it is a 11mm 12point.  Loosen and remove the nut from the end that bolts to the steering column.  Take a brass punch or wood dowel and knock the stud in.  Pull the stud as far out as it will go and it should release the steering column.  The stud / bolt will not come out of the intermediate shaft.  With a little hammer or crowbar you should be able to slide the shaft off the splines on either end.  Hope this helps.....  Good luck!
morpheus256
I'm in the middle of replacing a bad rag joint. Trying to get the intermediate shaft out of the car, it's hard for me to tell, but on the inside of the engine bay, on the firewall where the boot is do I only have to loosen the bolt to remove the shaft, or does it have a ridge on the inside shaft/steering column that requires the bolt to be fully removed?
What is the best way to reassemble everything to have the steering wheel straight when the wheels are straight?
edit: I had another look at it, it looks like there's just a nut going onto a stud at the u-joint, that's onto a splined shaft on the steering column. How in the hell does one get that ujoint off to remove the intermediate shaft? :)
