Mirror
Date: 04/15/2020 01:42 pm
Date: 12/31/2017 11:14 pm
Date: 07/30/2018 04:32 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 04/12/2017 08:15 am
Date: 07/08/2022 11:51 pm
Date: 02/18/2017 04:41 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
  • Online today: 586
  • Users: 1
  • Guests: 157
  • Total: 158
NO REAR BRAKES!!!! but great pedal?!?!?
Started by bbobcat75, August 03, 2011, 07:14:58 PM
Eric on wagon underneath leaf.  Fred   :)
spyville
I had the same problem after I did he rear shoes in a 76 trunk. No pressure in the rear but the fronts were great. The brake light came on. I went through the system and after I cleaned up the proportioning block where the wire comes out the light went off and I got fluid from the back again. The system works but if I push hard on the brake I hear a clunk and then the fronts only. So I am waiting for a master cylinder and a proportioning block now.
I think that the proportioning valve is bad and it blocks off the rear like when you lose a line.
I have no idea on the ebrake cable mine are under.
Proud Owner of the hardest working couch in America.
bbobcat75
ok have great pedal when appling brakes but the rear just spin, tryed to bleed but bleeders broke :hangover:  got new ones on way for tomorrow am.
and also wondering if the e-brake cable is suppose to be under the leaf spring?????on both sides its under it is a wagon, my hatch back are on the top of the leaf springs?!?!?any help will be great thanks again
eric
1975 mercury bobcat 2.8 auto
