convert to stick
Date: 05/19/2018 09:26 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Date: 10/10/2019 10:02 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 06/07/2021 08:14 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 08/26/2018 06:23 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 600
  • Guests: 322
  • Total: 322
trans ?
Started by PintoMan1, August 01, 2011, 09:53:17 AM
PintoMan1
thank you, but why would i have to change the bell housing? aren't they the same bolt pattern? or is it the top two bolt holes that are different? i know that some are closer then others. or are you talking about the four that bolt the trans to the housing that are different? i do realize that if i go 5spd i will have to change bells and other things.
thanks for all the input, i quess i have more research to do
1973 pinto runabout
It should if you change the bell housing . Also the Four Speeds came in alot of Fords with the 2.3. 1979 and up Mustangs with a 2.3 are going to be the most common but double check to see what size input shaft is in the car. Go to Autozone.com and look up a clutch set up, this is pretty easy and that will tell you what size the shaft is. As for a five speed again your going to change the bell housing but I do not know if a T-9 or T-5 will fit. However the 2.0 EAO Pinto motor was used in the U.K. for many different Fords over the years (Ford  Sierra RS500) etc so you might check ebay UK for the bell housing and other hot rod parts....Turbo heads and Cosworth Twin Cam Motors etc....
PintoMan1
can anyone tell me if a 4spd trans from a 2.3 will work on a 2.0? i may also want to put a 5spd in as well. can anyone tell me what will work as far as a trans that will work for the 2.0 and what cars they come from? and with any of these trans can i still use the cable?
thanks
1973 pinto runabout
