Date: 04/20/2017 08:56 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 10/04/2019 08:43 pm
Date: 07/13/2018 02:21 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 09/21/2018 11:35 am
front end parts
Date: 03/30/2018 12:48 pm
Date: 07/21/2017 11:49 am
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
  • Online today: 452
  • Guests: 199
  • Total: 199
Need help finding carb
Started by schuberg05, July 27, 2011, 08:26:51 PM
Is it a 1.6 a 2.0 or a 2.3......If it's a 2.3 than it has a 5200 series carb and it was used from 1974 to 1977. The rebuild kit is pretty much the same. The only difference is how the choke works, one uses water from the coolant system to heat the choke and the other uses is an electric element. So for a dune buggy it should not matter. Just take the carb in to the parts store and they should know what kind it is.....Try NAPA.
Take a picture of the engine and post it here. Chances are, someone will know by looking at the motor and at least get an idea of what carb it might be (what year that carb was put on the engine).   ;D
schuberg05
Well I have a doodlebug with a pinto motor and trans. That is what i am told. I don't know the year. Major problem finding parts. I know that the needs rebuilt and have people to rebuild it just can't get the kit with knowing the year. The carb that is on it is a 2bbl. Where on the block is the number? Found one on passenger side but those #'s don't seem to match when I go to parts store.
