Front sump oil pan
Date: 01/02/2017 06:54 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 02/04/2018 08:26 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 02/05/2020 11:06 am
Date: 03/27/2017 10:07 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 05/21/2019 11:50 am
  • Online today: 1,292
  • Guests: 525
  • Total: 525
'71 starter removal
Started by oldpony, July 21, 2011, 08:38:45 AM
oldpony
Thanks for the suggestions on the starter.  Went with raising the engine and everything went fine.  The starter is in and we are fired up again.
Mike in New Hampshire
72pair
I'm on the same page as oldkayaker. On my '72s, I always used a long extension and socket on the top bolt and a box end wrench on the bottom two. Then, pull the starter forward a bit and rotate. It just will slide between the motor mount and the rack. Done this a number of times and never touched the rack or raised the engine.  Good luck! JT
Every Pinto is a little different.  On my 71 2.0, the starter could be removed without moving the engine or rack.  I used most of my 3/8" extensions (maybe 20") to position the ratchet ahead of the rack.  May have used a universal too, don't remember.  This gets all three bolts out, if memory is correct.  With the starter loose, alternately twist it side to side to sort of unscrew the starter through/past the obstructions and drop it out.  Worth a try, good luck.
You either lower steering rack or get a 9/16" wrench and undo the 2 engine mount bolts and raise engine to clear rack.  Fred    :)
oldpony
After 50 some years of playing with cars, I feel like an idiot.  The starter on my 1971 Pinto 2000cc engine with an A/T needs to replaced.  The person that wrote the Pinto shop manual must have found something good to smoke the day he worked on the starter removal instructions.  So far I have removed the dust shield so I wouldn't have to fight with its tightening screw and the starter plunger cover so I can operate the plunger manually to turn the starter.  None of this has helped.  Is there something special that needs to be done in order to remove the old and install the new.
