1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 06/07/2021 08:14 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1979 hatch needed
Date: 05/13/2018 08:52 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
74 pinto
Date: 09/11/2016 06:32 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
  • Total Topics: 16,268
  • Online today: 155
  • Guests: 157
  • Total: 157
New car !
Started by Reeves1, June 30, 2011, 07:47:57 AM
its prob the shifter , you can not go into two gears at the same time without locking up the trans and the whole drivetrain , also you should not be able to move shift levers 1 and 2 aganst 3 and 4 , because of a pin in the middle (if its in place ) from doing so , if you can bring it back to where you Ooverhauled it to put it in if you can move both at the same time , they are offten left out my mistake and not safe to do so ,
Well, that didn't last long.....
First hard shift into 2nd & felt something go wrong. It's stuck in 2nd - but I can still shift into 1st. When I ease the clutch out it acts like it locks up the trans (like brakes on).
I can also shift in / out of 3 & 4.
I'll be inspecting the shifter today - hope I just forgot to tighten a bolt of nut.
Shifter mounting plate was 3 3/8" different.
Got some aluminum plate in town & made a new one. Looks & worked like factory.
Everything back in / on car.
Exhaust hangers this morning & road ready again.......except I may not have time to drive it.
Many home things to do before work starts up again.....
Bench fit shifter - all good.
Remove shifter & install trans.
Go to install shifter......and it will not work.
Took some measurements.... that I should have before....and the mounting plate is about an inch farther ahead than it was on the T-10.
Have to buy or make a new plate.....and pull the trans. Again.
FYI - guy on the BOSS 302 forum is selling his Tiger :
https://www.ebay.com/itm/1967-Sunbeam/132681091933?hash=item1ee468cb5d:g:gMUAAOSwKAJbNFem&vxp=mtr
I passed up a pair back in the early 80s......for 3k.  DUH !
I envy you owning a Tiger !
Took 4 days , lots of head scratching & calls to Long Shifters to get the shifter working properly.
Put it together as Long Shifters said & it wasn't even close to working.
Did my way & got all working as it should.
Doing some other small jobs, painting the trans & may have it all back together today.....?
Nice. I have heard some of the Cobra racers prefer the close ratio gears and have swapped with Tiger owners. I have not had that fortunate of an offer.
A trans with a STRONG reputation! Is this Toploader a close (2.32) or wide (2.78) ratio version? Generally the wide ratio version is preferable.  Unfortunately the early Tigers (like mine) came with the close ratio.
As noted in your post Toploaders aren't cheap.  Jeep used a version in their trucks from 80-96 in three different ratios.  I was hoping to pick up a wider ratio (actually Jeep's close ratio) cheap at a Pick Your Part (about $100) but after looking for around 15 years and only ever finding one..., it had the wrong gears (not the T-178, 3.01 1st gear I desired).
Glad to see this project is getting near the end. Enjoy.
I have two sets of shifter rods (one set is for a Top Loader).
I have 6 shifter arms (that bolt to trans) and not one will work on this Top Loader !
So I have to order new ones.....another delay !
I pick the Top Loader up this morning.
$800.00 for it & $875.00 ish to have it re-built.
Guess that will teach me for using a weak trans thinking I could get away with it due to a light weight car !
Tracked down a Top Loader & it turns out it was out of my car before I bought it !
Pick it up in a few days & will have it re-built.
With luck back on the road after the 20th.
K&N says no off set filter base for me. Looks like I have to make one........?
Too much HP for a Super T-10. Broke the flange on the main shaft. Page 11 has an exploded parts page: https://www.richmondgear.com/wp-content/uploads/pdfs/richmond/UPGRADED_SUPER_T10_MANUAL_v2.pdf
If anyone knows of a person with parts, please let me know.
I also need a 90 degree adapter for my speedo cable.
Quote from: Reeves1 on May 25, 2018, 07:40:28 PM
Funny you should mention what Horse I rode in on........ it was a BAWS 302 Pinto !
Yup, finally had it out on the road !
Stupid horse power !
Fast !
Also gets about 6 mpg  ;D
Love the smell of VP C-111 gas burning !
Bugs though... speedo cable takes a sharp 90 & it only lasted about 10 miles. Need to get a 90 adapter to fix.
Also lost 1st & second. Thinking shift fork. I'll know more in a week or so......
BUT... you had it out on the road!  Well done!
Fast !
Quote from: Reeves1 on May 24, 2018, 08:07:50 PM
I'm behind on up-dates.....for now the exhaust is done.
Car is dirty all over. Didn't get a chance to wash yet......
OMG!  Now I do know what  tubing wood truly is! ;D
Mufflers still not done. They keep messing up the coating.
Alignment done......got to run the car in town with open headers  ;D
Windshield was pushed back to today.
Work starts again so car has to wait. Again  :(
Headers have been bolted back on & exhaust made, which have been sent for coating. Should be back on Wed.
Picked up a barrel of VP C-111 fuel & will drain old fuel & fill with new fuel today.
Cleaning / painting the OEM rotors & calipers & re-installing.
Wilwood set up isn't what I want (will be selling this set).
Tuesday booked the car into a glass shop to install a new windshield.
Wed aft booked a front alignment.
Then re-install fenders etc & book a safety inspection.......
Headers re-installed.
Picked up a pair of Flo Pro Max mufflers # 11239
https://www.flopro.com/max.html
3" in/out, off set. Will be 3" to the ends.
Picked up some 3 1/2" pipe to make the reducers.
Couple days to finish & send for ceramic coating.
Gunna be loud  ;D
Ready to install, after a few other mods.
Sorry for the dented pipes. Original header builder didn't make them right & the only other option was to make a complete new set.
Have to pick up a set of stainless bolts for the slip joints.
I have a list of parts to buy to finish the exhaust to dump in front of the rear tires.....
Call last night.... Headers are done.
They will be picked up today from Edmonton & I'll pick them up this aft in town.
This is the set I re-built the back two tubes on each side.
Three of the front tubes had to be "adjusted" with a hammer.
Only other option was to build a complete new set from scratch.....which I nearly did. I have a different design in my head I was going to use. Even bought a new set of flanges to start with.....
Now to order the mufflers & mandrel bends to finish the exhaust. It will be reduced to three inch & kept that size to the ends.
About a week ago I sent the modified Headers in for re-coating (ceramic).
I the next few days I'll order the new valve springs & rockers.......
Fliping over backwards should not be a problem with 1/2 of the engine ahead of the front axle. That is unless your driving it backwards to take advantage of the better aeronautics going backwards.
Quote from: Reeves1 on December 19, 2017, 07:24:52 AM
It will also need anti flip over backwards devices  ;D
LOL , Perhaps a 300 lb bronze grill  ;D
Been a while since I posted on this.
Had a few asking about the car......
Going to put the OEM disk brakes back on - do not want to buy new wheels.
Needs front alignment, then fenders etc installed.
Engine needs new , stronger , valve springs. Going to order them when I can.
I'd still sell the car or just the engine. Let someone else finish it......going to be posting it up soon, but thought I'd mention it here first. Get in touch if interested.
B2 engine alone 15k
Whole thing 25k
Tonycando
Looking good,it's a piece of cake once you get into it hey.
I fully welded up all the seams & they are ready for re-coating.
Just have to get back to work for some disposable cash.....
