Date: 08/09/2018 07:49 am
Date: 02/28/2018 09:18 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
77-78 front grill
Date: 04/07/2017 12:35 am
Date: 09/09/2018 03:22 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Date: 09/17/2024 12:35 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
  • Online today: 586
  • Guests: 236
  • Total: 236
neutral safety swith issue
Started by r4pinto, June 28, 2011, 12:30:21 PM
Quote from: r4pinto on June 29, 2011, 12:03:18 PM
Found out the neutral safety switch is the same part on the C-3 as the reverse switch, so now I know the switch is bad. I got no reverse lights on the car & gotta use a trusty screwdriver to start the car. Oh well, I will go to a junkyard to get a replacement.
Well... fortunately, that shouldn't be TOO expensive!  Hang in there!
The plug still plugged in on the right or the one that is unplugged?
Any idea if it also operates the backup lights?
Matt here is the switch on a C-3.  Fred   :)
Hi guys,
I was having issues with the car cranking before & thought it was a bad neutral safety switch. Well, I went to Carlisle & the problem went away for the trip. It is now after Carlisle & the problem returned. While I was on lunch at work I started the car using a screwdriver & out of curiosity looked in my rearview mirror. No backup lights.
Now I know the fuse is good, as the turn signals work & the grounds are good as well. All was working for Carlisle, including the backup lights. The bulbs are brand new & have no breaks in the filiment.
My question is on a 77 Pinto 2.3 C3 automatic is the reverse switch part of the neutral safety switch? It has been a couple years since I did the transmission so I don't recall if it had one plug or two going to it.
Thanks for any info guys!
