Date: 09/09/2018 03:22 pm
Date: 02/18/2017 04:44 pm
convert to stick
Date: 05/19/2018 09:26 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 07/08/2017 08:25 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
  • Online today: 2,737
  • Guests: 2486
  • Total: 2486
Front/Rear Shock Mod
Started by don33, June 15, 2011, 05:45:26 PM
Regarding the front shocks, I did some searching and found that some of the Datsun/Nissan Pick up shocks came close to meeting the physical characteristics of Pinto shocks. But, being that you mentioned 90/10's I doubt there would be something specific for that. Regardless here is a link to that post and the small possibility that it leads to something for you. http://www.fordpinto.com/index.php?topic=25878.0
entropy
So did you ever get a set of those and, if so, how did they work out?  I need more weight transfer on my car and I'm starting to look at these...
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
don33
after some consulting with jugalo777                                                          the tentative plan is, for the fronts ......http://www.summitracing.com/parts/KON-802660SPA1/Application/?query=Make%7cFORD
and for the rear........
will probably get shocks from these guys since I will be using caltrac's  traction bars. they have 9 position adjustable rear shocks
http://www.calvertracing.com/
don33
wow, yeah I saw those, dont really want to spend that much on shocks, there  should be a little more economically priced quality shock
Dunno about the rear but in the front you could always run QA1 coil overs at right around 500 they aint cheap though.
http://www.speedwaymotors.com/Mustang-II-Bolt-On-Coil-Over-Kits,182.html
don33
jugalo777
the comp eng shocks are junk do/nt waste ur money . the afcos are for oval racing never work for drag,, i pm,d u some info
don33
well I guess everybody is running oem type shocks...?    I did find these for the front.
http://www.summitracing.com/parts/CEE-2639/   hopfully they make a rear to go with them.
If not possibly these.
http://www.summitracing.com/parts/AFC-1041/
don33
this would be for a drag car, specifically  90/10's in front and 50/50's in the rear.  or adjustables, like the ones that are available to the mustang crowd.
mpintotoo
hey pinto guys i been working with bilstines in la cal thay are maked a  sport shock for pintos with a maier sport package   the place  is calls rcd in la cal talk to steve he know my pinto and has made a sport shock for my old pinto racer  so get in touch with him
don33
thanks a lot there Dick for the informative reply... I used to be one of the local ministock people.
Talk to your local min-stock people.
don33
Has anybody ever modded the Front/rear shock mounts  to utilize after market shocks from another vehicle, say a mustang ?  the choices are huge compaired to the choices offered to the pinto world.
