Current Classifieds
Electrical
Date: 03/29/2017 11:37 am
Date: 03/07/2017 07:03 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 05/28/2017 03:20 pm
Date: 02/18/2017 04:44 pm
Date: 08/20/2017 01:34 pm
Date: 03/29/2019 07:20 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 09/01/2017 07:52 am
Author Topic: SHOCKING NEWS!!! (Well..., just shocks)  (Read 2859 times)
Offline Wittsend
  • Pinto Sr. Master
  • FeedBack: +241/-0
  • Total Badges: 8
    Badges: (View All)
    Tenth year Anniversary Mobile User Topic Starter Poll Voter 1000 Posts Linux User Windows User Fifth year Anniversary
« on: March 27, 2015, 02:40:11 PM »
I was poking around looking for cross reference shocks for the front of my Pinto.  I came across an interesting link regarding the need for "short" shocks for lowered, early Datsun pick up trucks.  Turns out the Pinto shock with its short length is a popular item. Someone at the site who works in an auto parts store came up with list of shocks that function in compressed/extended lengths similar to the Pinto. All the shocks listed go shorter/longer than the Pinto shock. Thus the range seems applicable. I'll cut & paste below but if you care here is a link to the site (scroll down to post #24) http://community.ratsun.net/topic/19595-shortest-shocks-you-can-find/page-2
I don't know if the mounting is all the same, but I'd think it would be adaptable.  Anyway, consider at your own risk. For the economically minded like myself ("Pick A Part is my Pep Boys") I'm intrigued. I'm far more likely to find decents shocks on a newer vehicle then some scruffy, EOL Pinto.
http://www.monroe.co...LengthSheet.pdf
 when ever someone comes into my store looking for a short shock i find out the stock number (unless they've changed the mount type) stock on a 71 521 is a monroe-matic 32206.
 PART  MOUNTING     LENGTHS
 NO.   Upper Lower  Comp. Ext.
 32206 S4    LS23   8.375 12.500
 S4 3/8 - 16 stem type
 LS23 12MM 1 1/4 bushing and sleeve type
 now you can change the upper mount as long as the stem is a bigger size because you can just drill it out and the lower is the same way. also you can mount a shock upside down (why not) works just fine been rockin shocks on my brothers truck for a long time upside down. so time to dig
 32134  S4 LS18 8.125 12.125 (this looks like a 76-81 larger Chrysler product shock)
 911047 S4 LS23 8.125 12.125 (this looks like a early-mid 2000's Nissan pick up shock)
 911171 S4 LS23 8.000 11.875 (this looks like a early-mid 2000's Nissan pick up shock) Note, I have seen some listings down into the '70s
 911245 S4 LS23 8.250 11.750 (this looks like a early-mid 2000's Nissan pick up shock)
 911529 S4 LS23 8.125 12.125 (this looks like a late 90's-mid 2000's Nissan pick up shock)
It seems likely there are "better fit" shocks, but all these six digit shocks seem applicable for the Nissan pick up/SUV application over a large range of years
 32118 S4 LS20 8.375c 11.000c Ford Pinto shock posted above
 911171 is your best shot
 cross reference in kyb is
 565045 monomax hp   $44
 kg5446 gas adjust   $36        at Baxter Auto Parts i work in vancouver washington
 application is a 2001 nissan xtera std suspension
Offline dga57
  • Chief Moderator / Admin
  • FordPinto.com Moderator
  • Pinto PooBAH
  • FeedBack: +208/-0
  • Gender: Male
  • Total Badges: 8
    Badges: (View All)
    Tenth year Anniversary Topic Starter Signature Poll Voter Mobile User Windows User 1000 Posts Fifth year Anniversary
Re: SHOCKING NEWS!!! (Well..., just shocks)
« Reply #1 on: March 27, 2015, 03:01:56 PM »
Appears to be really good information.  Thanks for sharing!
Dwayne :)
Offline dick1172762
  • Vintage Pinto Racer
  • PCCA Management Board
  • Pinto Sr. Master
  • FeedBack: +362/-0
  • Gender: Male
  • I'm a llama!
  • Total Badges: 7
    Badges: (View All)
    Topic Starter Signature Poll Voter Windows User 1000 Posts Tenth year Anniversary Fifth year Anniversary
« Reply #2 on: March 27, 2015, 03:27:51 PM »
Now you need to look for short rear shocks because when you REALLY lower a Pinto the rear shocks will bottom out. Even Koni will. One fix is to use a lowering block under the spring to lower the bottom eye mount. No one will need to tell you if this is necessary because you will think the rear end just fell out when you corner the car like a boy racer. One a lowered Pinto you should always mark the center of the travel on the shocks just to give you an idea of how much trouble your in.
Offline dick1172762
  • Pinto Sr. Master
  • FeedBack: +362/-0
  • Gender: Male
  • I'm a llama!
  • Total Badges: 7
    Badges: (View All)
« Reply #3 on: March 27, 2015, 03:44:47 PM »
Upside down shocks are used in racing because as used they are un sprung weight. Turn them over and they become sprung weight which is much better for racing.
Offline Wittsend
  • Pinto Sr. Master
  • FeedBack: +241/-0
  • Total Badges: 8
    Badges: (View All)
« Reply #4 on: March 27, 2015, 04:02:53 PM »
"Now you need to look for short rear shocks because when you REALLY lower a Pinto the rear shocks will bottom out. "
Mission accomplished! The wagon (what I have) has shocks that are roughly 1-1/2" longer to begin with.  And in my ever reaching frugality I just employed standard Pinto rear shocks and used spacers/washers (as many as I could safely use and still tighten the nuts) to simulate the longer shock and center it. Remove them and the problem is solved.  ;)
  Anyway, I was considering alternative shocks at a stock height.  It was only the Datsun article that was seeking to lower the vehicle. I just posted it for the shock alternatives. Yesterday I was blowing leaves out from under the Pinto and was again reminded of the approximate 3"-4" ground clearance I have with the Turbo Coupe exhaust. That and living in a city that was on the pioneering end of using speed bumps on residential streets for speed control says "go no lower." :'(
Offline jonz2pinto
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Another Pinto Driver
  • Total Badges: 4
    Badges: (View All)
    Topic Starter Signature Linux User Mobile User
« Reply #5 on: March 27, 2015, 08:05:40 PM »
One time I wanted air shocks forthe rear of a pinto sedan.All I could find that was short enough was for a mid 70s camaro(I think).It had the bolt thru end though.Simple was to bend 1/16 steel into u shape with a bolt thru bottom as a stud and holes at each end.Bolted adapter to shock mount then shock to adapter.Only changed mount to one inch higher(shock was short enough for this).
Pinto-is short for pint-o-fun.
Offline Reeves1
  • Pinto Master
  • FeedBack: +104/-0
  • Gender: Male
  • BAWS302
  • Total Badges: 6
    Badges: (View All)
    Tenth year Anniversary Topic Starter Signature Fifth year Anniversary Windows User 1000 Posts
« Reply #6 on: March 27, 2015, 08:31:26 PM »
I have: 4 NOS front & 2 NOS rear shocks  ;D
