Custom Pinto Project
Date: 06/12/2016 07:37 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
nos core support
Date: 01/03/2020 09:39 pm
1979 pinto
Date: 04/19/2018 02:02 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 08/22/2017 09:21 pm
Date: 02/28/2018 09:37 am
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 09/02/2021 08:21 am
  • Online today: 427
  • Guests: 373
  • Total: 373
steering help
Started by americanpintobean, June 15, 2011, 02:18:58 PM
O'Reilly's has these, it's one of those packages marked "HELP". It is a universal kit that has bolts instead of rivets, and WILL fit the Pinto driveshaft.
Americanpintobean: I bought one of these, but ended up not needing it. If you PM me, and send me your address, I will send it to you free of charge.
Let me know.
I don't know the part #, it's a standard ford part but not an exact fit for the pinto, maybe take yours apart and bring with you. I do believe that you do have to drill/enlarge the holes for the bolts to fit, I have my mechanic fix for me and why I don't know exactly the mod needed to make it work but think I'm correct.
An exact fit/replacement is unavailable to my knowledge. Ask at the auto parts store, they should be able to help you if the employee has any experience.
americanpintobean
yes, the rubber.  do you have a part no. @ autozone?
Quote from: wedge446 on June 15, 2011, 06:32:55 PM
The rubber piece?(rag joint)
If thats the piece your looking for I used the small one that was found in autozones help section
and yes, remove the rivets, I think you'll have to enlarge some holes for the new bolts but that is how we all fix this problem. Hope that helps  ;D
americanpintobean
rag joint is the only bad part.  Can I remove the rivets and replace them with bolts if I cut them off?  And where can I find the rag joint material?
Quote from: americanpintobean on June 17, 2011, 09:57:04 AM
i need one with a good rag joint
is the rag joing the only problem with the one you have? and the rest of it in working order?
americanpintobean
i need one with a good rag joint, not power assist steering.  have parts for trade.  door glass, rear trunk model glass, many other parts.
I might have one but I am pretty sure the rag joint will need to be replaced.  The coupler that attaches to the rack differs between power and manual steering cars so you need to make sure you get one from a manual car or you will need to swap the end from you old one.  Give me a couple days and I will get back to you.
americanpintobean
i am looking for the entire piece.  in good condition, and with a good rag joint.
americanpintobean
Do you have a power or manual steering car?
wedge446
americanpintobean
I need this steering piece.  It bolts to the end of the steering column then connects to a piece going to the rack. I have parts for trade.
