2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 01/24/2017 12:36 pm
Date: 01/04/2017 04:07 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 05/03/2024 05:37 am
71-71 speedo cable
  • Online today: 640
  • Guests: 597
  • Total: 597
carburator
Started by Honchoman, April 14, 2005, 09:00:19 PM
Hey honchoman,
I KNOW my 10.5to 1 cr Purple Pinto can handel all four barrels that are manually opened.
I used a machine screw and some small washers that could be infinately adjustable.
And like your uncles Camero It screamed. Well untill I sheared the flywheel bolts off.
The Holley 5200 is like a 4 barrel cut in 1/2!!!!!
Honchoman
hmmmm. my uncle had a camaro with a holley double-pumper that he rigged so all four barrels would open at the same time ( he he he that thing screamed). do you think a pinto 2.0 can handle that much gas?
billnall
Yes, there is a primary and a secondary barrel.
Ford Parts Man
Honchoman
my 74 2.0 4speed has the original carb (2bbl). i was looking at it last night, and noticed something.   it seems that when the throttle is opened, only the drivers side butterfly opens. is it supposed to be like that?
someone let me know before i make it so both butterflies open at the same time, and possibly ruin the engine   (i think i can do it with a spring)
Thanks!!!
