Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 03/15/2023 02:16 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 03/14/2020 01:52 pm
Date: 08/13/2018 02:46 pm
Date: 08/22/2017 09:21 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 01/06/2017 11:42 pm
pinto for sale
Date: 09/11/2016 09:47 pm
  • Online today: 533
  • Guests: 325
  • Total: 325
71 pinto lower ball joints
Started by Wayne Kocian, May 13, 2011, 07:24:19 PM
WIV8Pinto
Hey, if you wanna play, you gotta pay!!! ha ha....I'm sure when I need them they will probably be $100...!
1972 V8 Pinto Wagon 351 Windsor C4 4.88 gears...& hang on!!!!
Also 02 F150 4x4 and 96 Explorer sport 4x4
289Wagon
 OUCH ! $68.85 + on ePay -- Don't know about GS, but NOS at Miller is      $45.00 +
WIV8Pinto
A couple of years ago, I took some rough measurements of 71-72 and 79 suspension parts.  Almost nothing interchanges.
http://www.fordpinto.com/general-help/early-vs-late-front-suspensions/msg75756/#msg75756
Pintojoe stated that the 74  lower ball joint can be modified to fit a 73 (and I assume 71-72 also).
http://www.fordpinto.com/general-help/pinto-suspension-shared-with-others/msg2450/#msg2450
Other than the ball joints, the bolt hole spacing on the upper control arms is different between the 71-73 and the 74 and up control arms.  I also believe the lower control arm bushings are shorter in length.
Wayne Kocian
The reason I'm asking is I want to install tubular control arms and they list them for '74 and newer. I have been doing my research to find out what the difference is between the early and late models.  The upper bj's are the same but arm length I don't know. As for the lower I thought perhaps the ball joint stud may be different. If it's a matter of replacing the knuckle to make the later stuff work that wont be so bad since they are easy to find. Has any one ever encountered this?  Wayne.
WIV8Pinto
Whoops, my bad...sorry about that...it tells me that when I need lower ball joints, I will have the same problem!! And they sound really expensive!! What are we going to do about replacement parts for our Pintos?
They make uppers? But not lowers???  weird....
72pair
The above Ford # is correct. The Moog # is K8163. I have a couple sets of each, but they are not cheap as they are hard to find. JT :)
289Wagon
 The Ford number I come up with for the lower is D1FZ-3050-A
That number is supposed to be available at :
Green Sales Company, OH  and Miller Obsolete Parts in Binghamton,NY
If you decide to go with either one of them- PLEASE!!!! verify that number to be correct for your vehicle - PLEASE !!!
I don't claim to be a parts expert & NOS/obsolete parts aren't cheap.
I've never recieved an email reply from GSC so you might just want to call them to start with.
Wayne Kocian
Hi WIV8Pinto,
Been there done that, nothing for the lowers in that year
WIV8Pinto
Wayne Kocian
Hi, I'm trying to find a part # for lower ball joints for my '71. I have found the number for '74 and up and no one seems to know if they are the same or not. Can someone please help me?
Wayne.
