Date: 09/20/2018 11:01 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 04/13/2017 04:56 am
looking for parts
Date: 06/19/2020 02:32 pm
Date: 08/24/2018 02:50 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 12/31/2017 09:03 pm
Date: 03/30/2021 12:29 pm
  • Online today: 447
  • Guests: 372
  • Total: 372
1978 Pinto Rear Axle Specs?
Started by pumpford, May 09, 2011, 10:13:37 AM
If you don't know the difference between a 6.75 and a 8 inch the 6.75 has a cover bolted on the rear side of the pumpkin to access the gears the 8 inch third member bolts into the pumpkin from the front and comes out in one piece.
Once we know which axle you have we can give you more info.
is it the 6.75 In rear end or the 8 in rear end?
pumpford
Can anyone tell me the specs of a 1978 Pinto left rear axle shaft? I need the axle shaft length, the spline, spline diameter and bearing diameter information.
Thank you in advance!
