1976 Squire wagon
Date: 09/12/2018 10:30 pm
79 pinto small parts
Date: 04/24/2019 03:16 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Date: 11/23/2017 05:44 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 12/31/2017 09:03 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
  • Online today: 624
  • Guests: 564
  • Total: 564
Fuel injection
Started by wedge446, April 27, 2011, 03:10:26 PM
ctompkins31
So there is a seperate float inthe tc. Did anyone ever find a properly functioning aftermarket sending unit? Correct fit and ohm range?
ctompkins31
In tank not intake. I also read about but do not remember there being a second fuel pump on the 88 tc. Will that be needed? Please answer. I know this post has been done before. I have navigated through pages and pages. There are a few who have sent the tanks to Moyer but the specifics are left out.
ctompkins31
I am thinking about sending my tank and the turbocoupe pump to Moyer to do the intake setup. I do not remember there being a fuel float on the turbocoupe fuel pump. How is the fuel level gauged?
wedge446
I thought of doing that but if I go that route I will need to install a surge tank/sump at the bottom inside of the gas tank to keep the pump from starving.
Quote from: Mike Modified on April 27, 2011, 05:03:13 PM
Perhaps something like this, made by an 'early Ford' guy for 30's & 40's gas tanks, $50.00:
Some description here (direct): http://bobdrake.com/RNPA/RNPA-HR-9003.pdf
Seems to me to have some advantages: larger fuel lines & in-tank fuel pump.
Mike Modified
RSM
I was going to put a fuel cell in my 80 wagon but decided not to. I don't really want to hassle with cutting the back of the car open and sheet metal everything back in...saves time. I'm going to put a sump at the rear of the stock tank and run that. That way i can fill the car normally and have the fuel gauge as well. It's all personal preference.
wedge446
I have a dilemma.
I installing a 2.3 fuel injected turbo into my 75 wagon so I need to revamp the fuel system. I want to install a fuel cell because I have a pin hole in the stock tank.
Do I;
1) Repair the hole in the stock tank while its out set it up for an in tank fuel pump and forget the fuel cell?
2)Install the fuel cell and set it up for an external high pressure pump?
With an external pump setup, would I need a serge tank?
Fuel cell would be a 16gal. flat bottom if that matters
With the fuel cell I will have to cut the rear floor and make a sump area to mount the cell into..
Any insight welcome.
