2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 05/19/2018 04:56 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 01/10/2022 03:41 pm
Date: 08/30/2018 12:59 am
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Date: 07/01/2019 03:17 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 07/10/2016 10:17 am
  • Online today: 295
  • Guests: 148
  • Total: 148
update on my turbo pinto
Started by carbomb, April 08, 2011, 07:07:17 PM
carbomb
finally got valve seals in it. Every one of them were split. doesn't smoke a bit now
carbomb
the oil lines are sock so the drain tube is significantly bigger and i don't think it's the PCV i drove it with the original one and it smoked and i put a brand new replacement motocraft one and it is still smoking. I'll try new valve seals (worth a try for 20$ counting the tool) and report back
What size oil line are you running " to " the turbo and what size line is the dump line ? Sometimes you can over oli the turbo and it will leak past the seal and sometimes if you done have a large enough Dia dump tube it will back up the oil and leak past the seal.
map351
Make sure your PCV valve is not sticking open or just disconnect it and see if the oil issue stops.
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
carbomb
http://www.youtube.com/watch?v=350LQATMqNk
got my intercooler and blow off valve along with my center counsel complete and my dash looking better. up to 18 psi and it runs great. next step is a new turbo. I think my seals are going out. it smokes and there is constantly oil in the turbo inlet and the vacume system. anyone have advice to find out if this is where the oil is coming from? it could be valve seals or rings since the motor has 130 on it
