1978 fuel sendng unit
Date: 05/27/2020 09:54 am
looking for parts
Date: 06/19/2020 02:32 pm
Date: 11/05/2016 09:03 pm
Date: 02/22/2017 01:58 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 05/28/2017 03:20 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 03/17/2019 03:57 am
  • Online today: 548
  • Guests: 525
  • Total: 525
how to test a oil pan for leaks
Started by oldeguy, April 01, 2011, 08:57:17 AM
oldeguy
Update...tested with gas...a leak showed up like pronto! re-welded, now it's good!
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
oldeguy
Guys thanks for the feedback...I like the oil addition!
Oh also if yah want to smooth out the welds Jb weld works well just smear it over the welds it helps seal small leaks and if done right you cant even tell the pan was modded.
Bill, with the light oil in fuel it makes a leak very easy to detect.  Fred   :)
i used water since it way way way thinner then oil. Worked great then i used a little rubbing alcohol to get rid of the excess water left in it after dumping the rest out. Worked for me just fine mine has 0 leaks.
oldeguy
oldeguy
