Date: 09/06/2020 01:57 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Racing seats
Date: 10/24/2019 09:41 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 12/15/2018 02:21 am
Date: 10/10/2019 10:02 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
  • Online today: 2,457
  • Guests: 567
  • Total: 567
1978 ford pinto 2.3 liter
Started by delizious, March 31, 2011, 05:19:55 PM
Like Fred said the 78 2.3s do not have points. They have electronic ignition. I would suggest replacing the distributor cap & rotor, as well as checking the ignition box. It is a square box mounted to the driver side of the engine compartment, next to the ignition coil. It would also be a good idea to check the coil as well.
delizious
I hope that adjusting the distributor points will make this pinto run more correctly, recently I've been having problems whenever I start it up cold. I have to literally push down on the accelerator pedal...than after it shifts my car jerks.
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
Plug .034    time is 6@550 rpm.  points you should not have.  Fred   :)
delizious
I need the dwell, timing, spark plug gap and point gap for my 1978 ford pinto. Pllleeassseee
