Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 09/12/2018 04:07 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 05/03/2024 05:37 am
Pinto Wagon
Date: 05/25/2018 01:50 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 02/28/2018 09:33 am
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
  • Online today: 376
  • Guests: 387
  • Total: 387
Found a place to get replacement muffler for 1980 Pinto!
Started by Number1Pinto, March 30, 2011, 05:26:11 PM
older cars are tough to find exhaust system parts for as you guys are discovering.  when i had my shop back in the '70's even then it was getting tough to find direct fit replacements for cars built in the late '60's.
if you have a muffler shop anywhere near you that is equipped to build custom systems, the guys/gals at the shop should be able to research what is available using the manufacturers dimensional criteria as compared to what you have on your car (inlet & outlet ID & OD as well as the case dimensions & shape along with the placement of the inlet & outlet on the ends of the muffler) to arrive at a workable solution.
if this local exhaust shop does any amount of truly custom work this should be a piece of cake for them to do.
in any case, if no direct fit replacements are available a shop with a good bender & an operator to work it should be able to fit you up with something to both keep it quiet (if that's what you desire) AND fit like a glove.
IMHO
shotgun494
I also have a a 77 pinto with a 2.3 . You said you got a muffler at Advance was it a direct fit? If so , do you have the part number?  I have an adavnce up here but the said they had no listing for it and there was nothing they could do. I appreciate it. Thanks Jim
"Mild to Wild"
tinkerman73
I had to buy a new muffler for my 77 and it was readily found at advanced auto!
Jody Michielsen
bbobcat75
im surprised that the 1980 muffler would not fit other years?!>!?!
just asking thanks
eric
1975 mercury bobcat 2.8 auto
Quote from: bbobcat75 on March 30, 2011, 05:40:19 PM
what motor size is that muffler for??
one would think a 4banger would be different from a v6
thanks
eric
The 1980 Pinto only came with the 2.3L. I know because I tried to get a V6 one in 1980 to tow a boat. Towed one anyway.
bbobcat75
thanks
eric
Number1Pinto
Walker makes an exact replacement muffler for 1980 Pinto:  Tru-Fit model 18126.  You should be able to find it locally or google it.  I got mine at O'Reilly's Auto Parts.  Neither O'Reilly's or Walker's catalogs go back to 1980, so it's impossible to get information from them.  Hope this helps!
