1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
72 Pinto parts
Date: 12/04/2018 09:56 pm
Date: 04/30/2023 04:31 pm
Date: 09/03/2018 08:58 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 08/02/2019 04:18 pm
Date: 04/14/2023 06:15 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
  • Online today: 584
  • Guests: 519
  • Total: 519
'75 2.3 camshaft timing marks
Started by stinsonj, March 12, 2011, 11:51:25 PM
This link is for a latter model 2.3 but I believe it should work for your cam timing.
http://www.turbotbird.com/techinfo/CamTiming/Cam%20Timing%20Belt%20Replacement%20and%20Set%20Up.htm
A couple words of caution found from playing with the 2.0 engines.  Take up the slack in the driven side of the belt (crank-aux gear-cam) before setting final tension/timing.  Avoid large moves in rotating things backwards before full tension is set and locked down (took teeth off the expensive belt ounce doing this).
stinsonj
Can someone please tell me where the cam timing marks are on a 1975 2.3 liter and how they need to align when the number 1 cylinder is at tdc?? Thanks in advance for any help!
