Date: 07/13/2018 02:21 pm
Date: 08/20/2017 01:34 pm
Date: 09/02/2021 08:21 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 03/30/2021 12:29 pm
Date: 03/25/2019 09:02 pm
Date: 03/16/2017 10:00 pm
  • Online today: 292
  • Guests: 297
  • Total: 297
Radiator
Started by ctpinto, March 04, 2011, 07:07:19 PM
ctpinto
Ok, I think I'll try swapping them this week. My original fan should still fit.  Any other experiences or suggestions with radiators here? Oh, and does the front valence get replaced when installing a fiberglass spoiler? I might eventually do that.
72pair
I've been running 2.3s in one of my 72s with the 2.0 radiator and had no heating problems even on hot days here in SC. I run a 12" electric fan with a thermostatic control in front of the radiator since I have no clearance for a engine driven fan. I'm even using a power pulley and large diameter pump pulley which slows the water pump for less drag. I don't know how this will work on a turbo engine, but I plan on finding out some day! I used a maverick radiator for a while, but you are correct that the lower valance will not bolt up unless it is notched or reshaped aka bent severely down. Good luck!JT
ctpinto
I've been doing work converting my 80 to a 72 and i came across the radiator issue. i believe ill have to cut off some of the support and probably need a different shorter radiator so i can bolt on the front valence. i have a 72 donor car with the 2.0 radiator but i though this would be a little small seeing that i'd like to drop in a 2.3t in the summer. im on kinda a low budget so i afford having a custom aluminum one made up lol. anyone else done this before? any suggestions? Thanks
Will
