Date: 07/03/2025 04:35 pm
Date: 04/20/2017 08:56 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 06/25/2021 12:59 am
looking for parts
Date: 06/19/2020 02:32 pm
Date: 09/01/2017 11:58 am
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Online today: 266
  • Guests: 235
  • Total: 235
rear end help
Started by 71ss351, April 01, 2005, 08:04:16 PM
Quote from: CONSFIRE on June 16, 2005, 03:06:09 PM
FIND A 1957 TO 1959 9" REAR END IN YOUR LOCAL WRECKING YARD. SPRING PADS MATCH THE PINTO SPRINGS PERFECTLY. IT'S A DROP IN FIT PHIL(CONSFIRE)
Uhh, yeah, that is a good idea but those rearends are getting real hard to find in junk yards around my neck of the woods.............. ;), also, after you find one , you will need to rebuild the center section and change out the 2:80 gears.... ;D
CONSFIRE
CHEAPRACER
Very smart. When I bought my '88 5.0 LX with the 8.8, I had already heard too many horror stories about the 7.5 and also changed my center diff right away even though the 8.8 solved the issue.
71ss351
I have got an aftermarket posi unit in it.
71 Pinto
351 Interceptor w/ comp 274 cam
C-5 Transmission
7.5 rear end with 3.73 posi trac.
CHEAPRACER
Be easy on the 7.5, crappy center pinion pin will bend under too much power and take out your pinion gears. It happened 3 times on my friends '83 5.0 GL mustang.
pintoman
I installed a 7.5 in my 80 Rallye this last summer.Had to drill out the spring plates for the ubolts.But did not have your problem with not having room for the holes.PINTOMAN
71ss351
I recently installed a mustang 7.5 rear end in my 71 and had the perches welded on for the leaf springs, and had to go with bigger u-bolts, the problem is I had to drill the holes out on the mounting plate, I was able to get the outside drilled but I can not get to the inside, there is only one u-bolt on each side, does any one have any suggestions
71 Pinto
C-5 Transmission
