2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 11/14/2019 04:02 am
Date: 05/13/2021 05:33 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 07/20/2017 01:23 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
pro stock front end
Date: 06/28/2019 07:43 pm
  • Online today: 3,091
  • Online ever: 3,214 (Yesterday at 10:48:59 AM)
  • Guests: 1575
  • Total: 1575
2.8L problems
Started by hoots, February 28, 2011, 07:02:09 PM
flash041
I would say it may be the timing gear. It turns the cam, which turns the distributor.Its ver common. The original in nylon.My original lasted about 60k.I replaced it with metal gears. It can be replaced without pulling the engine.
If it's oil pump driven like the 2.3l 4cyl, it could be your oil pump. If not, does it run off an auxiliary shaft like the 2.3 does?
Sorry, I'm not familiar with the 2.8 cologne.
hoots
I have a 75 Bobcat with the 2.8L. The Distributor is not turning, I pulled it out and checked the drive gear which doesn't turn when the engine is rotated. Just wondering if anyone has experience with this problem?
