Date: 08/27/2018 11:11 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 09/01/2017 07:52 am
Date: 09/09/2018 03:22 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 01/28/2017 12:30 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Date: 05/13/2021 05:33 pm
  • Online today: 624
  • Guests: 414
  • Total: 414
Boss 429 Pinto
Started by cfb289, February 27, 2011, 09:31:39 PM
Must have it done by now ?
Any video of it racing ?
thecustommuffler
Headers came out great and I really dig the coil mount locations. Must be a deep dish piston, where is the pin on the piston? Those chambers look mighty small for 8 pounds and up. Do you have anymore pics? Looked like a motor mount with a press fit delrin or poly resin isolator.
mrskydog
Man!! what a Class act.....Nice car! I just checked this Post out ,and what a nice Clean Job .....again Nice...,Drip,...Drool... :P
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
sedandelivery
electric H2O pump? I like the way the plate on the front really cleans up the engine compartment.  it looks real good
cfb289
Almost done.  The engine is back in the car, and runs.  I took the car out for a drive Sunday.  Biggest thing left to do is fab an air cleaner / air box that actually fits under the hood.
Craig
71 Pinto, 562 CuIn Boss 429, EFI, TH400, 9 Inch rear with 4.11 Detroit Locker
cfb289
It has been awhile, time for an update.  Here are a few engine build pictures.
Craig
don33
WoW, I am just stuned, that is one awesome build, I cant even imagine driving that beast.   Vids when its done man...
Craig - soon time to flash that B9 up ?
cfb289
Srt:  I just looked and I don't have any pictures of the Boss 9 from farther away.  I don't have the mock up engine in the car any longer.  I do have pictures of something else interesting.  Once I knew that I had to move the steering and master cylinders I wanted to make sure that I moved them far enough that a 427 SOHC would fit.  So I raided my friends stockpile of SOHC parts and spent an after noon mocking that up also.
Craig
cfb289
Reeves:  In an ideal world it would be done already, but it isn't.  I'm hoping to have it running by July 1.  We'll see.
Srt:  Here are some pictures from last year when I had the 408W in it.
Craig
how about a shot of the motor / car from a short distance, say, about 10' or so. motor/front end/driverside?
excellent build.
Looking forward to the day it is fired up !
cfb289
It has been over a month, so it is time for another update.  Headers are now finished.  Just need to send them out to be coated.  The engine block has been deburred, line honed, square decked, and getting ready to be bored.  Here are the pictures.
Craig
cfb289
Time for an update.  I made a die to form header tubes to the flanges. And have the driver side header all tacked together.
Craig
Thank you for answering my questions !
I'll send you a PM now.
tinkerman73
Dang, those are both some serious builds! I love the 68 cougars due to the tail lights! LOL. Hes one lucky fellow with that car! However, that pinto is going to be killer too! WOW!
Jody Michielsen
cfb289
As I said the yellow 67 cougar belongs to a friend.  Currently it has a blown 427 wedge in it.  Hopefully it will be done this spring.  His future plans are to replace the wedge engine with a SOHC.
Craig
cfb289
Thanks everyone.
Reeves: You have a good eye, that is indeed a cougar in the background.  It belongs to a friend of mine.  We have been helping each other with building cars and engines for as long as I can remember.  I'll post a few pictures of it in a bit.  For your second question.  The paint on my Pinto is 2006 Mustang Vista Blue Metallic.
Dave:  Just to clarify, I didn't make the throttle body in the last picture.  It was bought from Wilson Manifolds.  Good luck on your 78.  Just do the best you can, and be happy that you did it yourself.
Here is a better picture of the roughed in front motor plate.  I'm very lucky to have access to a mill and lathe to be able to make cool pieces like this.
Craig
Wow ! Very nice ! Would love to see that run at the track !
Looks like a yellow Cougar in the shop as well ? Any story on it ? Pictures ?
One last question.....what is the color code/name for the blue on the Pinto ?
Looks amazing! Loving the aluminum! I hope that when I drop the 289 or 302 into my 78 that I can do it this well and beautifully!
postalpony
Craig-- You make an old man proud of the way you do it yourself.
Its a pleasure to see some good old CRAFTSMANSHIP!!
All that & a Boss 9, what more could a man want.
   Good luck & keep up the good work.  Sincerely   Dick Mathias
Now all we do is HAUL!
cfb289
Here are some pictures of modifying the intake for EFI.
Craig
     At least you've got a plan!!!  Go for it!
cfb289
Now will the new engine fit.
Lets see, the steering hits the oil filter adapter.  A double u-joint fixes the steering, and lets lower the steering column 2" for better header clearance.
Now I'll move the master cylinders outboard about 3" to fix that problem.
Craig
cfb289
My pinto has been done for a few years, so its now time to tear it apart and build a new engine.  Rather than find my old build post from 4 years ago, I'll just start a new thread.  Here is a few cylinder head pictures to start off with.
Craig
